[MapServer-users] Some remote SVG files doesn't in 8.1
Seth G sethg at geographika.co.uk
Wed Jul 19 14:54:39 PDT 2023
Hi Martin,
The issue seems to be related to the viewBox property in the SVG file.
If you save the SVG source from view-source:https://raw.githubusercontent.com/NordjyllandsTrafikselskab/gisimages/ca64d7a849c7cf0290ec41ec263a97b9195d0ff8/01.01.01.Bus.svg and remove the following text in a text editor the symbols display correctly:
viewBox="0 0 396.85 396.85"
Maybe it could be an upstream issue, or something has changed upstream that breaks symbol size calculations.
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Tue, Jul 18, 2023, at 1:59 AM, Steve Lime wrote:
> There seems to be a regression with svg- I have another sample file that doesn’t render correctly (or at all). Just need to find a little time to resolve it.
> On Tue, Jul 11, 2023 at 12:10 PM Martin Høgh <mh at mapcentia.com> wrote:
>> I've a MapFile with a point layer using a class style with a SVG symbol:
>> CLASS
>>      NAME 'point'
>>      STYLE
>>          SYMBOL
>> 'https://raw.githubusercontent.com/NordjyllandsTrafikselskab/gisimages/ca64d7a849c7cf0290ec41ec263a97b9195d0ff8/01.01.01.Bus.svg'
>>      END
>> END
>> In 7.6 this works fine, but in 8.1 the SVG symbol is not showing (no
>> errors but the image is blank). But if change the SVG file to e.g.:
>> https://dev.w3.org/SVG/tools/svgweb/samples/svg-files/AJ_Digital_Camera.svg
>> it works. So I guess it's something with the SVG file?
>> MapServer version 8.0.1 PROJ version 7.2 GDAL version 3.4 OUTPUT=PNG
>> OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=SOS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=FASTCGI
>> SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE INPUT=FLATGEOBUF
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230719/ff3c5186/attachment.htm>
More information about the MapServer-users mailing list
