[MapServer-users] FW: Unable to build mapserver 8 on WIndows with v8 support
Seth G sethg at geographika.co.uk
Thu Jun 8 10:13:05 PDT 2023
I've not used this functionality myself, and I remember at a MapServer codesprint there were problems trying to compile this over 5 years ago. In answer to your question about getting it working with MapServer 8 - I doubt this is possible without updating the source code.
As Jeff wrote it will need someone to attempt to update this to work with newer versions. It would require experience of the v8 engine and its API changes in the last 10 years to get this working again. A few links that may be useful to get started:
- the code - https://github.com/MapServer/MapServer/tree/4b7ad75eda030eca919b7f7d06de8a8e95ca52f3/mapscript/v8
- the RFC about its implementation - https://mapserver.org/development/rfc/ms-rfc-106.html
- the original pull request - https://github.com/MapServer/MapServer/pull/4827
Just to note this support is to allow shapes to be manipulated with JS functions in a Mapfile, and unrelated to MapScript. Adding MapScript JS support is probably easier as it is one of the SWIG target languages.
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Thu, Jun 8, 2023, at 6:22 PM, Сухно Николай wrote:
> in this case the situation is different
> https://github.com/MapServer/MapServer/issues/5484
> The author of the topic tried to use the compiled libraries from
> version 3.14, although 3.20 is needed
> Version 7.0.4 is also discussed there.
> I have a positive experience building a mapserver 7.0.0 with v8 support
>  for windows and Linux(centos 7).
> If someone needs it, I can give instructions on this.
> But my original question is about mapserver 8.
> -----Original Message-----
> From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On
> Behalf Of Jeff McKenna
> Sent: Thursday, June 8, 2023 6:32 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [MapServer-users] FW: Unable to build mapserver 8 on
> I honestly don't think that any love has been given to V8 support in
> many years (see the discussion at
> https://github.com/MapServer/MapServer/issues/5484 )
> Might be good to give that issue a ping, and for you to post your exact
> errors there, and maybe even a pull request if possible.
> PS. as MS4W distributes all mapscripts, V8 is not yet included, and I'm
> willing to add it....but it seems it will take some effort, a community
> effort...
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G http://gatewaygeo.com/
> On 2023-06-08 12:09 p.m., nikolay.su at outlook.com wrote:
>> Good day to all!
>> I'm trying to compile a mapserver with v8 support for windows
>> as written in the docs
>> https://mapserver.org/installation/v8.html#obtaining-compiling-and-installing-v8-and-v8-mapscript <https://mapserver.org/installation/v8.html#obtaining-compiling-and-installing-v8-and-v8-mapscript> «you have to use v8 3.20»
>> The problem in v8, that  is a very old version and it can't be built for
>> MSVC versions higher than 2013
>> At the same time, the SDK  mapserver 8 is only available for 2022
>> https://gisinternals.com/sdk.php <https://gisinternals.com/sdk.php>
>> Previously I built v8 under MSVC 2013, but this lib’s  not work with
>> MSVC 2022 due to binary incompatibility
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
