[MapServer-users] FW: Unable to build mapserver 8 on WIndows with v8 support
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jun 8 09:55:31 PDT 2023
My answer still applies, for any version of MapServer.  Maybe you could
add build tests to the MapServer repository, so that it shows your
errors (and then V8 is tested for every commit automagically, against
all platforms).
To summarize: it just needs a champion, like yourself, to get this
moving again inside the MapServer core.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-06-08 1:22 p.m., Сухно Николай wrote:
> in this case the situation is different  https://github.com/MapServer/MapServer/issues/5484
> The author of the topic tried to use the compiled libraries from version 3.14, although 3.20 is needed
> Version 7.0.4 is also discussed there.
> I have a positive experience building a mapserver 7.0.0 with v8 support  for windows and Linux(centos 7).
> If someone needs it, I can give instructions on this.
> But my original question is about mapserver 8.
> -----Original Message-----
> From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On Behalf Of Jeff McKenna
> Sent: Thursday, June 8, 2023 6:32 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [MapServer-users] FW: Unable to build mapserver 8 on WIndows with v8 support
> I honestly don't think that any love has been given to V8 support in many years (see the discussion at
> https://github.com/MapServer/MapServer/issues/5484 )
> Might be good to give that issue a ping, and for you to post your exact errors there, and maybe even a pull request if possible.
> PS. as MS4W distributes all mapscripts, V8 is not yet included, and I'm willing to add it....but it seems it will take some effort, a community effort...
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training co-founder of FOSS4G http://gatewaygeo.com/
> On 2023-06-08 12:09 p.m., nikolay.su at outlook.com wrote:
>> Good day to all!
>> I'm trying to compile a mapserver with v8 support for windows
>> as written in the docs
>> https://mapserver.org/installation/v8.html#obtaining-compiling-and-installing-v8-and-v8-mapscript <https://mapserver.org/installation/v8.html#obtaining-compiling-and-installing-v8-and-v8-mapscript> «you have to use v8 3.20»
>> The problem in v8, that  is a very old version and it can't be built for
>> MSVC versions higher than 2013
>> At the same time, the SDK  mapserver 8 is only available for 2022
>> https://gisinternals.com/sdk.php <https://gisinternals.com/sdk.php>
>> Previously I built v8 under MSVC 2013, but this lib’s  not work with
>> MSVC 2022 due to binary incompatibility
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
