[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 4 09:38:07 PDT 2023
Yes I meant that, it forces it to be the start of the string, for security.
Can you also try changing WEB/METADATA param to  "wms_enable_request"
(I may be missing something else obvious)
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-05-04 1:32 p.m., Chris Cantey wrote:
> Did you mean to have the ^ in that string?   MS_MAP_PATTERN
> "^/home/web/gis/tmp/mapserver/".
> It seemed to mess it up, so i reverted back to MS_MAP_PATTERN
> "/home/web/gis/tmp/mapserver/"
> Same errors
> On Thu, May 4, 2023 at 8:55 AM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
>     Hi Chris,
>     Can you try this in your config file:
>          MS_MAP_PATTERN "^/home/web/gis/tmp/mapserver/"
>     thanks,
>     -jeff
>     Jeff McKenna
>     http://gatewaygeo.com/ <http://gatewaygeo.com/>
>     On 2023-05-04 10:30 a.m., Chris Cantey wrote:
>      > Hello all, I need some help.
>      > We are building a new web server a rebuilding mapserver on it,
>     migrating
>      > from 6.4 to 8.0. But in testing, we keep getting the
>     "msWMSDispatch():
>      > settings." error.
>      > But we have that configured in our map file under
>     map>web>metadata. So
>      > I'm not sure what is going on. Config file, map file, URL, error,
>     query
>      > string, and error below.
>     _______________________________________________
>     MapServer-users mailing list
>     MapServer-users at lists.osgeo.org <mailto:MapServer-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-users
>     <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> Chris Cantey
> geo-odyssey.com <http://geo-odyssey.com>
More information about the MapServer-users mailing list
