[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey cantey0701 at gmail.com
Thu May 4 10:58:35 PDT 2023
No problem: https://pastebin.com/Ssk0cp1b
On Thu, May 4, 2023 at 12:51 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Chris can you paste your latest mapfile at https://pastebin.com/ and
> paste the link here for everyone?  (and for any future mailing list
> messages, please use that method, for sharing your mapfile and config
> files)
> thanks,
> -jeff
> On 2023-05-04 2:45 p.m., Chris Cantey wrote:
> > We were also a little concerned about web>template. We didn't see
> > anywhere what exactly we were supposed to put in the TEMPLATE document.
> > its basically the same html document as
> > https://dev.gis.lcc.mn.gov/tmp/mapserver/
> > <https://dev.gis.lcc.mn.gov/tmp/mapserver/> but with <!-- MapServer
> > Template --> on top.
> > CC
> > On Thu, May 4, 2023 at 12:32 PM Chris Cantey <cantey0701 at gmail.com
> > <mailto:cantey0701 at gmail.com>> wrote:
> >     I need that t-shirt! The quotes are in the mapfile, I think gmail
> >     just hyperlinked the string.
> >     I am kind of testing 2 ways: Using the browser(a few methods there),
> >     using linux: mapserv
> >     "QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
> >     When I do that, I still get a validation error:
> >     [Thu May  4 12:18:06 2023].428388 loadParams() QUERY_STRING:
> >     [Thu May  4 12:18:06 2023].428506 msCGILoadMap(): Web application
> >     error. CGI variable "map" fails to validate.
> >     I'm wondering on the front end if there's a projection issue, I see
> >     green network activity: https://dev.gis.lcc.mn.gov/tmp/mapserver/
> >     On Thu, May 4, 2023 at 12:29 PM Jeff McKenna
> >     <mailto:jmckenna at gatewaygeomatics.com>> wrote:
> >         Also, your onlineresource is missing quotes, such as:
> >         "wms_onlineresource"
> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
> >         -jeff
> >         Jeff McKenna
> >         GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> >         co-founder of FOSS4G
> >         http://gatewaygeo.com/ <http://gatewaygeo.com/>
> >         On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
> >          > Thanks.  I think you solved any validation issues ( this
> >         request would
> >          > not validate, for example :
> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map>
> )   so it's something else, very minor likely (I've got that t-shirt too,
> ha)
> >          > -jeff
> >          > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
> >          >> Thanks, Jeff.. I found that out, thanks.
> >          >> I will work down from your points.
> >          >> Besc,
> >          >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
> >         <mailto:jmckenna at gatewaygeomatics.com>>>
> >          >> wrote:
> >          >>     Also note, that the regular expression "^" trick applies
> >         to the
> >          >>     MS_MAP_PATTERN in the config file (not the MS_ERRORFILE
> >         path in the
> >          >>     mapfile).
> >          >>     Thanks for using MapServer Chris,
> >          >>     -jeff
> >          >>     --     Jeff McKenna
> >         Training
> >         <http://gatewaygeo.com/ <http://gatewaygeo.com/>>
> >          >>     On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
> >          >>      > More points for your consideration:
> >          >>      > - make sure all layers have a PROJECTION object
> >          >>      > - remove any old references to the
> >         (non-standard/non-existing)
> >          >>      > EPSG:900913, replace with EPSG:3857  (see
> >         https://epsg.io/3857 <https://epsg.io/3857>
> >          >>     <https://epsg.io/3857 <https://epsg.io/3857>> )
> >          >>      > - remove all warnings from your GetCapabilities
> >         response, every
> >          >>     single
> >          >>      > warning, there should be no warnings in the response,
> >         before you
> >          >>     move to
> >          >>      > testing GetMap requests
> >          >>      > - if you have PostGIS/db connections, consider
> >         setting EXTENT
> >          >> at the
> >          >>      > layer-level, to improve speed for your clients (review
> >          >>     optimizations at
> >          >>      > https://mapserver.org/optimization/vector.html
> >         <https://mapserver.org/optimization/vector.html>
> >         <https://mapserver.org/optimization/vector.html>> )
> >          >>      > - during GetMap testing, comment any TEMPLATE params
> >         in mapfile
> >          >>      > -jeff
> >          >>     _______________________________________________
> >          >>     MapServer-users mailing list
> >          >> MapServer-users at lists.osgeo.org
> >         <mailto:MapServer-users at lists.osgeo.org>
> >         <mailto:MapServer-users at lists.osgeo.org>>
> >          >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> >         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> >         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>>
> >          >> Chris Cantey
> >          >> geo-odyssey.com <http://geo-odyssey.com>
> >         <http://geo-odyssey.com <http://geo-odyssey.com>>
> >     Chris Cantey
> > Chris Cantey
> Jeff McKenna
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230504/0721a32b/attachment.htm>
More information about the MapServer-users mailing list
