[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 4 10:58:54 PDT 2023
Also, make sure you can generate a valid map image with a map2img
commandline call.
-jeff
On 2023-05-04 2:51 p.m., Jeff McKenna wrote:
> Chris can you paste your latest mapfile at https://pastebin.com/ and
> paste the link here for everyone?  (and for any future mailing list
> messages, please use that method, for sharing your mapfile and config
> files)
> thanks,
> -jeff
> On 2023-05-04 2:45 p.m., Chris Cantey wrote:
>> We were also a little concerned about web>template. We didn't see
>> anywhere what exactly we were supposed to put in the TEMPLATE
>> document. its basically the same html document as
>> https://dev.gis.lcc.mn.gov/tmp/mapserver/
>> <https://dev.gis.lcc.mn.gov/tmp/mapserver/> but with <!-- MapServer
>> Template --> on top.
>> CC
>> On Thu, May 4, 2023 at 12:32 PM Chris Cantey <cantey0701 at gmail.com
>> <mailto:cantey0701 at gmail.com>> wrote:
>>     I need that t-shirt! The quotes are in the mapfile, I think gmail
>>     just hyperlinked the string.
>>     I am kind of testing 2 ways: Using the browser(a few methods there),
>>     using linux: mapserv
>>     "QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
>>     When I do that, I still get a validation error:
>>     [Thu May  4 12:18:06 2023].428388 loadParams() QUERY_STRING:
>>     [Thu May  4 12:18:06 2023].428506 msCGILoadMap(): Web application
>>     error. CGI variable "map" fails to validate.
>>     I'm wondering on the front end if there's a projection issue, I see
>>     green network activity: https://dev.gis.lcc.mn.gov/tmp/mapserver/
>>     On Thu, May 4, 2023 at 12:29 PM Jeff McKenna
>>     <jmckenna at gatewaygeomatics.com
>>     <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>>         Also, your onlineresource is missing quotes, such as:
>>         "wms_onlineresource"
>> "https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map>"
>>         -jeff
>>         --         Jeff McKenna
>>         GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>>         co-founder of FOSS4G
>>         http://gatewaygeo.com/ <http://gatewaygeo.com/>
>>         On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
>>          > Thanks.  I think you solved any validation issues ( this
>>         request would
>>          > not validate, for example :
>> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map> )   so it's something else, very minor likely (I've got that t-shirt too, ha)
>>          > -jeff
>>          > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
>>          >> Thanks, Jeff.. I found that out, thanks.
>>          >> I will work down from your points.
>>          >> Besc,
>>          >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
>>          >> <jmckenna at gatewaygeomatics.com
>>         <mailto:jmckenna at gatewaygeomatics.com>>>
>>          >> wrote:
>>          >>     Also note, that the regular expression "^" trick applies
>>         to the
>>          >>     MS_MAP_PATTERN in the config file (not the MS_ERRORFILE
>>         path in the
>>          >>     mapfile).
>>          >>     Thanks for using MapServer Chris,
>>          >>     -jeff
>>          >>     --     Jeff McKenna
>>          >>     GatewayGeo: Developers of MS4W, MapServer Consulting and
>>         Training
>>          >>     co-founder of FOSS4G
>>          >> http://gatewaygeo.com/ <http://gatewaygeo.com/>
>>         <http://gatewaygeo.com/ <http://gatewaygeo.com/>>
>>          >>     On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
>>          >>      > More points for your consideration:
>>          >>      > - make sure all layers have a PROJECTION object
>>          >>      > - remove any old references to the
>>         (non-standard/non-existing)
>>          >>      > EPSG:900913, replace with EPSG:3857  (see
>>         https://epsg.io/3857 <https://epsg.io/3857>
>>          >>     <https://epsg.io/3857 <https://epsg.io/3857>> )
>>          >>      > - remove all warnings from your GetCapabilities
>>         response, every
>>          >>     single
>>          >>      > warning, there should be no warnings in the response,
>>         before you
>>          >>     move to
>>          >>      > testing GetMap requests
>>          >>      > - if you have PostGIS/db connections, consider
>>         setting EXTENT
>>          >> at the
>>          >>      > layer-level, to improve speed for your clients (review
>>          >>     optimizations at
>>          >>      > https://mapserver.org/optimization/vector.html
>>         <https://mapserver.org/optimization/vector.html>
>>          >>     <https://mapserver.org/optimization/vector.html
>>         <https://mapserver.org/optimization/vector.html>> )
>>          >>      > - during GetMap testing, comment any TEMPLATE params
>>         in mapfile
>>          >>      > -jeff
>>          >>     _______________________________________________
>>          >>     MapServer-users mailing list
>>          >> MapServer-users at lists.osgeo.org
>>         <mailto:MapServer-users at lists.osgeo.org>
>>          >> <mailto:MapServer-users at lists.osgeo.org
>>         <mailto:MapServer-users at lists.osgeo.org>>
>>          >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
>>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>>
>>          >> Chris Cantey
>>          >> geo-odyssey.com <http://geo-odyssey.com>
>>         <http://geo-odyssey.com <http://geo-odyssey.com>>
>>     --     Chris Cantey
>> Chris Cantey
Jeff McKenna
More information about the MapServer-users mailing list
