[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey cantey0701 at gmail.com
Thu May 4 11:00:25 PDT 2023
I also changed the wms_srs to "wms_srs" "EPSG:4326 EPSG:3857"
So ignore that part of pastebin
On Thu, May 4, 2023 at 12:59 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Also, make sure you can generate a valid map image with a map2img
> commandline call.
> -jeff
> On 2023-05-04 2:51 p.m., Jeff McKenna wrote:
> > Chris can you paste your latest mapfile at https://pastebin.com/ and
> > paste the link here for everyone?  (and for any future mailing list
> > messages, please use that method, for sharing your mapfile and config
> > files)
> > thanks,
> > -jeff
> > On 2023-05-04 2:45 p.m., Chris Cantey wrote:
> >> We were also a little concerned about web>template. We didn't see
> >> anywhere what exactly we were supposed to put in the TEMPLATE
> >> document. its basically the same html document as
> >> https://dev.gis.lcc.mn.gov/tmp/mapserver/
> >> <https://dev.gis.lcc.mn.gov/tmp/mapserver/> but with <!-- MapServer
> >> Template --> on top.
> >> CC
> >> On Thu, May 4, 2023 at 12:32 PM Chris Cantey <cantey0701 at gmail.com
> >> <mailto:cantey0701 at gmail.com>> wrote:
> >>     I need that t-shirt! The quotes are in the mapfile, I think gmail
> >>     just hyperlinked the string.
> >>     I am kind of testing 2 ways: Using the browser(a few methods there),
> >>     using linux: mapserv
> >>     "QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
> >>     When I do that, I still get a validation error:
> >>     [Thu May  4 12:18:06 2023].428388 loadParams() QUERY_STRING:
> >>     [Thu May  4 12:18:06 2023].428506 msCGILoadMap(): Web application
> >>     error. CGI variable "map" fails to validate.
> >>     I'm wondering on the front end if there's a projection issue, I see
> >>     green network activity: https://dev.gis.lcc.mn.gov/tmp/mapserver/
> >>     On Thu, May 4, 2023 at 12:29 PM Jeff McKenna
> >>     <mailto:jmckenna at gatewaygeomatics.com>> wrote:
> >>         Also, your onlineresource is missing quotes, such as:
> >>         "wms_onlineresource"
> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
> >>         -jeff
> >>         --         Jeff McKenna
> >>         GatewayGeo: Developers of MS4W, MapServer Consulting and
> Training
> >>         co-founder of FOSS4G
> >>         http://gatewaygeo.com/ <http://gatewaygeo.com/>
> >>         On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
> >>          > Thanks.  I think you solved any validation issues ( this
> >>         request would
> >>          > not validate, for example :
> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map>
> )   so it's something else, very minor likely (I've got that t-shirt too,
> ha)
> >>          > -jeff
> >>          > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
> >>          >> Thanks, Jeff.. I found that out, thanks.
> >>          >> I will work down from your points.
> >>          >> Besc,
> >>          >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
> >>         <mailto:jmckenna at gatewaygeomatics.com>>>
> >>          >> wrote:
> >>          >>     Also note, that the regular expression "^" trick applies
> >>         to the
> >>          >>     MS_MAP_PATTERN in the config file (not the MS_ERRORFILE
> >>         path in the
> >>          >>     mapfile).
> >>          >>     Thanks for using MapServer Chris,
> >>          >>     -jeff
> >>          >>     --     Jeff McKenna
> >>         Training
> >>         <http://gatewaygeo.com/ <http://gatewaygeo.com/>>
> >>          >>     On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
> >>          >>      > More points for your consideration:
> >>          >>      > - make sure all layers have a PROJECTION object
> >>          >>      > - remove any old references to the
> >>         (non-standard/non-existing)
> >>          >>      > EPSG:900913, replace with EPSG:3857  (see
> >>         https://epsg.io/3857 <https://epsg.io/3857>
> >>          >>     <https://epsg.io/3857 <https://epsg.io/3857>> )
> >>          >>      > - remove all warnings from your GetCapabilities
> >>         response, every
> >>          >>     single
> >>          >>      > warning, there should be no warnings in the response,
> >>         before you
> >>          >>     move to
> >>          >>      > testing GetMap requests
> >>          >>      > - if you have PostGIS/db connections, consider
> >>         setting EXTENT
> >>          >> at the
> >>          >>      > layer-level, to improve speed for your clients
> (review
> >>          >>     optimizations at
> >>          >>      > https://mapserver.org/optimization/vector.html
> >>         <https://mapserver.org/optimization/vector.html>
> >>         <https://mapserver.org/optimization/vector.html>> )
> >>          >>      > - during GetMap testing, comment any TEMPLATE params
> >>         in mapfile
> >>          >>      > -jeff
> >>          >>     _______________________________________________
> >>          >>     MapServer-users mailing list
> >>          >> MapServer-users at lists.osgeo.org
> >>         <mailto:MapServer-users at lists.osgeo.org>
> >>         <mailto:MapServer-users at lists.osgeo.org>>
> >>          >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> >>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> >>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>>
> >>          >> Chris Cantey
> >>          >> geo-odyssey.com <http://geo-odyssey.com>
> >>         <http://geo-odyssey.com <http://geo-odyssey.com>>
> >>     --     Chris Cantey
> >> Chris Cantey
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230504/9fae8b70/attachment.htm>
More information about the MapServer-users mailing list
