[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey cantey0701 at gmail.com
Thu May 4 11:03:40 PDT 2023
I forgot about map2img!
map2img -m mapserver.map -o test.png  -map_debug 3
returns:
msDrawMap(): Image handling error. Unable to initialize image. <br>
msCalculateScale(): General error message. Invalid image extent,
minx=-1.000000, miny=-1.000000, maxx=-1.000000, maxy=-1.000000. <br>
On Thu, May 4, 2023 at 1:00 PM Chris Cantey <cantey0701 at gmail.com> wrote:
> I also changed the wms_srs to "wms_srs" "EPSG:4326 EPSG:3857"
> So ignore that part of pastebin
> On Thu, May 4, 2023 at 12:59 PM Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> Also, make sure you can generate a valid map image with a map2img
>> commandline call.
>> -jeff
>> On 2023-05-04 2:51 p.m., Jeff McKenna wrote:
>> > Chris can you paste your latest mapfile at https://pastebin.com/ and
>> > paste the link here for everyone?  (and for any future mailing list
>> > messages, please use that method, for sharing your mapfile and config
>> > files)
>> > thanks,
>> > -jeff
>> > On 2023-05-04 2:45 p.m., Chris Cantey wrote:
>> >> We were also a little concerned about web>template. We didn't see
>> >> anywhere what exactly we were supposed to put in the TEMPLATE
>> >> document. its basically the same html document as
>> >> https://dev.gis.lcc.mn.gov/tmp/mapserver/
>> >> <https://dev.gis.lcc.mn.gov/tmp/mapserver/> but with <!-- MapServer
>> >> Template --> on top.
>> >> CC
>> >> On Thu, May 4, 2023 at 12:32 PM Chris Cantey <cantey0701 at gmail.com
>> >> <mailto:cantey0701 at gmail.com>> wrote:
>> >>     I need that t-shirt! The quotes are in the mapfile, I think gmail
>> >>     just hyperlinked the string.
>> >>     I am kind of testing 2 ways: Using the browser(a few methods
>> there),
>> >>     using linux: mapserv
>> >>     "QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
>> >>     When I do that, I still get a validation error:
>> >>     [Thu May  4 12:18:06 2023].428388 loadParams() QUERY_STRING:
>> >>     [Thu May  4 12:18:06 2023].428506 msCGILoadMap(): Web application
>> >>     error. CGI variable "map" fails to validate.
>> >>     I'm wondering on the front end if there's a projection issue, I see
>> >>     green network activity: https://dev.gis.lcc.mn.gov/tmp/mapserver/
>> >>     On Thu, May 4, 2023 at 12:29 PM Jeff McKenna
>> >>     <jmckenna at gatewaygeomatics.com
>> >>     <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>> >>         Also, your onlineresource is missing quotes, such as:
>> >>         "wms_onlineresource"
>> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
>> >>         -jeff
>> >>         --         Jeff McKenna
>> >>         GatewayGeo: Developers of MS4W, MapServer Consulting and
>> Training
>> >>         co-founder of FOSS4G
>> >>         http://gatewaygeo.com/ <http://gatewaygeo.com/>
>> >>         On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
>> >>          > Thanks.  I think you solved any validation issues ( this
>> >>         request would
>> >>          > not validate, for example :
>> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map>
>> )   so it's something else, very minor likely (I've got that t-shirt too,
>> ha)
>> >>          > -jeff
>> >>          > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
>> >>          >> Thanks, Jeff.. I found that out, thanks.
>> >>          >> I will work down from your points.
>> >>          >> Besc,
>> >>          >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
>> >>         <mailto:jmckenna at gatewaygeomatics.com>>>
>> >>          >> wrote:
>> >>          >>     Also note, that the regular expression "^" trick
>> applies
>> >>         to the
>> >>          >>     MS_MAP_PATTERN in the config file (not the MS_ERRORFILE
>> >>         path in the
>> >>          >>     mapfile).
>> >>          >>     Thanks for using MapServer Chris,
>> >>          >>     -jeff
>> >>          >>     --     Jeff McKenna
>> and
>> >>         Training
>> >>         <http://gatewaygeo.com/ <http://gatewaygeo.com/>>
>> >>          >>     On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
>> >>          >>      > More points for your consideration:
>> >>          >>      > - make sure all layers have a PROJECTION object
>> >>          >>      > - remove any old references to the
>> >>         (non-standard/non-existing)
>> >>          >>      > EPSG:900913, replace with EPSG:3857  (see
>> >>         https://epsg.io/3857 <https://epsg.io/3857>
>> >>          >>     <https://epsg.io/3857 <https://epsg.io/3857>> )
>> >>          >>      > - remove all warnings from your GetCapabilities
>> >>         response, every
>> >>          >>     single
>> >>          >>      > warning, there should be no warnings in the
>> response,
>> >>         before you
>> >>          >>     move to
>> >>          >>      > testing GetMap requests
>> >>          >>      > - if you have PostGIS/db connections, consider
>> >>         setting EXTENT
>> >>          >> at the
>> >>          >>      > layer-level, to improve speed for your clients
>> (review
>> >>          >>     optimizations at
>> >>          >>      > https://mapserver.org/optimization/vector.html
>> >>         <https://mapserver.org/optimization/vector.html>
>> >>         <https://mapserver.org/optimization/vector.html>> )
>> >>          >>      > - during GetMap testing, comment any TEMPLATE params
>> >>         in mapfile
>> >>          >>      > -jeff
>> >>          >>     _______________________________________________
>> >>          >>     MapServer-users mailing list
>> >>          >> MapServer-users at lists.osgeo.org
>> >>         <mailto:MapServer-users at lists.osgeo.org>
>> >>         <mailto:MapServer-users at lists.osgeo.org>>
>> >>          >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
>> >>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>>
>> >>          >> Chris Cantey
>> >>          >> geo-odyssey.com <http://geo-odyssey.com>
>> >>         <http://geo-odyssey.com <http://geo-odyssey.com>>
>> >>     --     Chris Cantey
>> >> Chris Cantey
>> Jeff McKenna
>> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> Chris Cantey
> geo-odyssey.com
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230504/51140785/attachment.htm>
More information about the MapServer-users mailing list
