[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey cantey0701 at gmail.com
Thu May 4 10:00:05 PDT 2023
Thanks, Jeff.. I found that out, thanks.
I will work down from your points.
Besc,
On Thu, May 4, 2023 at 11:57 AM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Also note, that the regular expression "^" trick applies to the
> MS_MAP_PATTERN in the config file (not the MS_ERRORFILE path in the
> mapfile).
> Thanks for using MapServer Chris,
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
> > More points for your consideration:
> > - make sure all layers have a PROJECTION object
> > - remove any old references to the (non-standard/non-existing)
> > EPSG:900913, replace with EPSG:3857  (see https://epsg.io/3857 )
> > - remove all warnings from your GetCapabilities response, every single
> > warning, there should be no warnings in the response, before you move to
> > testing GetMap requests
> > - if you have PostGIS/db connections, consider setting EXTENT at the
> > layer-level, to improve speed for your clients (review optimizations at
> > https://mapserver.org/optimization/vector.html )
> > - during GetMap testing, comment any TEMPLATE params in mapfile
> > -jeff
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230504/85f61353/attachment.htm>
More information about the MapServer-users mailing list
