[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 4 10:13:11 PDT 2023
Thanks.  I think you solved any validation issues ( this request would
not validate, for example :
https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
)   so it's something else, very minor likely (I've got that t-shirt
too, ha)
-jeff
On 2023-05-04 2:00 p.m., Chris Cantey wrote:
> Thanks, Jeff.. I found that out, thanks.
> I will work down from your points.
> Besc,
> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
>     Also note, that the regular expression "^" trick applies to the
>     MS_MAP_PATTERN in the config file (not the MS_ERRORFILE path in the
>     mapfile).
>     Thanks for using MapServer Chris,
>     -jeff
>     Jeff McKenna
>     GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>     co-founder of FOSS4G
>     http://gatewaygeo.com/ <http://gatewaygeo.com/>
>     On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
>      > More points for your consideration:
>      > - make sure all layers have a PROJECTION object
>      > - remove any old references to the (non-standard/non-existing)
>      > EPSG:900913, replace with EPSG:3857  (see https://epsg.io/3857
>     <https://epsg.io/3857> )
>      > - remove all warnings from your GetCapabilities response, every
>     single
>      > warning, there should be no warnings in the response, before you
>     move to
>      > testing GetMap requests
>      > - if you have PostGIS/db connections, consider setting EXTENT at the
>      > layer-level, to improve speed for your clients (review
>     optimizations at
>      > https://mapserver.org/optimization/vector.html
>     <https://mapserver.org/optimization/vector.html> )
>      > - during GetMap testing, comment any TEMPLATE params in mapfile
>      > -jeff
>     _______________________________________________
>     MapServer-users mailing list
>     MapServer-users at lists.osgeo.org <mailto:MapServer-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-users
>     <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> Chris Cantey
> geo-odyssey.com <http://geo-odyssey.com>
Jeff McKenna
More information about the MapServer-users mailing list
