[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey cantey0701 at gmail.com
Thu May 4 10:32:49 PDT 2023
I need that t-shirt! The quotes are in the mapfile, I think gmail just
hyperlinked the string.
I am kind of testing 2 ways: Using the browser(a few methods there), using
linux: mapserv
"QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
When I do that, I still get a validation error:
[Thu May  4 12:18:06 2023].428388 loadParams() QUERY_STRING:
[Thu May  4 12:18:06 2023].428506 msCGILoadMap(): Web application error.
CGI variable "map" fails to validate.
I'm wondering on the front end if there's a projection issue, I see green
network activity: https://dev.gis.lcc.mn.gov/tmp/mapserver/
On Thu, May 4, 2023 at 12:29 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Also, your onlineresource is missing quotes, such as:
> "wms_onlineresource"
> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
> > Thanks.  I think you solved any validation issues ( this request would
> > not validate, for example :
> )   so it's something else, very minor likely (I've got that t-shirt too,
> ha)
> > -jeff
> > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
> >> Thanks, Jeff.. I found that out, thanks.
> >> I will work down from your points.
> >> Besc,
> >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
> >> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> >> wrote:
> >>     Also note, that the regular expression "^" trick applies to the
> >>     MS_MAP_PATTERN in the config file (not the MS_ERRORFILE path in the
> >>     mapfile).
> >>     Thanks for using MapServer Chris,
> >>     -jeff
> >>     --     Jeff McKenna
> >>     http://gatewaygeo.com/ <http://gatewaygeo.com/>
> >>     On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
> >>      > More points for your consideration:
> >>      > - make sure all layers have a PROJECTION object
> >>      > - remove any old references to the (non-standard/non-existing)
> >>      > EPSG:900913, replace with EPSG:3857  (see https://epsg.io/3857
> >>     <https://epsg.io/3857> )
> >>      > - remove all warnings from your GetCapabilities response, every
> >>     single
> >>      > warning, there should be no warnings in the response, before you
> >>     move to
> >>      > testing GetMap requests
> >>      > - if you have PostGIS/db connections, consider setting EXTENT
> >> at the
> >>      > layer-level, to improve speed for your clients (review
> >>     optimizations at
> >>      > https://mapserver.org/optimization/vector.html
> >>     <https://mapserver.org/optimization/vector.html> )
> >>      > - during GetMap testing, comment any TEMPLATE params in mapfile
> >>      > -jeff
> >>     _______________________________________________
> >>     MapServer-users mailing list
> >>     MapServer-users at lists.osgeo.org
> >> <mailto:MapServer-users at lists.osgeo.org>
> >>     https://lists.osgeo.org/mailman/listinfo/mapserver-users
> >>     <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> >> Chris Cantey
> >> geo-odyssey.com <http://geo-odyssey.com>
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230504/baae3f85/attachment.htm>
More information about the MapServer-users mailing list
