[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey
cantey0701 at gmail.com
Thu May 4 10:45:56 PDT 2023
We were also a little concerned about web>template. We didn't see anywhere
what exactly we were supposed to put in the TEMPLATE document. its
basically the same html document as
https://dev.gis.lcc.mn.gov/tmp/mapserver/ but with <!-- MapServer Template
--> on top.
CC
On Thu, May 4, 2023 at 12:32 PM Chris Cantey <cantey0701 at gmail.com> wrote:
> I need that t-shirt! The quotes are in the mapfile, I think gmail just
> hyperlinked the string.
> I am kind of testing 2 ways: Using the browser(a few methods there), using
> linux: mapserv
> "QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
> When I do that, I still get a validation error:
> [Thu May 4 12:18:06 2023].428388 loadParams() QUERY_STRING:
> [Thu May 4 12:18:06 2023].428506 msCGILoadMap(): Web application error.
> CGI variable "map" fails to validate.
> I'm wondering on the front end if there's a projection issue, I see green
> network activity: https://dev.gis.lcc.mn.gov/tmp/mapserver/
> On Thu, May 4, 2023 at 12:29 PM Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> Also, your onlineresource is missing quotes, such as:
>> "wms_onlineresource"
>> https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map
>> -jeff
>> Jeff McKenna
>> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>> co-founder of FOSS4G
>> http://gatewaygeo.com/
>> On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
>> > Thanks. I think you solved any validation issues ( this request would
>> > not validate, for example :
>> ) so it's something else, very minor likely (I've got that t-shirt too,
>> ha)
>> > -jeff
>> > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
>> >> Thanks, Jeff.. I found that out, thanks.
>> >> I will work down from your points.
>> >> Besc,
>> >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
>> >> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>> >> wrote:
>> >> Also note, that the regular expression "^" trick applies to the
>> >> MS_MAP_PATTERN in the config file (not the MS_ERRORFILE path in the
>> >> mapfile).
>> >> Thanks for using MapServer Chris,
>> >> -jeff
>> >> -- Jeff McKenna
>> >> http://gatewaygeo.com/ <http://gatewaygeo.com/>
>> >> On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
>> >> > More points for your consideration:
>> >> > - make sure all layers have a PROJECTION object
>> >> > - remove any old references to the (non-standard/non-existing)
>> >> > EPSG:900913, replace with EPSG:3857 (see https://epsg.io/3857
>> >> <https://epsg.io/3857> )
>> >> > - remove all warnings from your GetCapabilities response, every
>> >> single
>> >> > warning, there should be no warnings in the response, before you
>> >> move to
>> >> > testing GetMap requests
>> >> > - if you have PostGIS/db connections, consider setting EXTENT
>> >> at the
>> >> > layer-level, to improve speed for your clients (review
>> >> optimizations at
>> >> > https://mapserver.org/optimization/vector.html
>> >> <https://mapserver.org/optimization/vector.html> )
>> >> > - during GetMap testing, comment any TEMPLATE params in mapfile
>> >> > -jeff
>> >> _______________________________________________
>> >> MapServer-users mailing list
>> >> MapServer-users at lists.osgeo.org
>> >> <mailto:MapServer-users at lists.osgeo.org>
>> >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >> <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
>> >> Chris Cantey
>> >> geo-odyssey.com <http://geo-odyssey.com>
> Chris Cantey
> geo-odyssey.com
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230504/9a6f83a5/attachment-0001.htm>
More information about the MapServer-users
