[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 4 11:07:27 PDT 2023
Ah, you're missing EXTENT at the MAP level, below SIZE
-jeff
On 2023-05-04 3:03 p.m., Chris Cantey wrote:
> I forgot about map2img!
> map2img -m mapserver.map -o test.png  -map_debug 3
> returns:
> msDrawMap(): Image handling error. Unable to initialize image. <br>
> msCalculateScale(): General error message. Invalid image extent,
> minx=-1.000000, miny=-1.000000, maxx=-1.000000, maxy=-1.000000. <br>
> On Thu, May 4, 2023 at 1:00 PM Chris Cantey <cantey0701 at gmail.com
> <mailto:cantey0701 at gmail.com>> wrote:
>     I also changed the wms_srs to "wms_srs" "EPSG:4326 EPSG:3857"
>     So ignore that part of pastebin
>     On Thu, May 4, 2023 at 12:59 PM Jeff McKenna
>     <jmckenna at gatewaygeomatics.com
>     <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>         Also, make sure you can generate a valid map image with a map2img
>         commandline call.
>         -jeff
>         On 2023-05-04 2:51 p.m., Jeff McKenna wrote:
>          > Chris can you paste your latest mapfile at
>         https://pastebin.com/ <https://pastebin.com/> and
>          > paste the link here for everyone?  (and for any future
>         mailing list
>          > messages, please use that method, for sharing your mapfile
>         and config
>          > files)
>          > thanks,
>          > -jeff
>          > On 2023-05-04 2:45 p.m., Chris Cantey wrote:
>          >> We were also a little concerned about web>template. We
>         didn't see
>          >> anywhere what exactly we were supposed to put in the TEMPLATE
>          >> document. its basically the same html document as
>          >> https://dev.gis.lcc.mn.gov/tmp/mapserver/
>         <https://dev.gis.lcc.mn.gov/tmp/mapserver/>
>         <https://dev.gis.lcc.mn.gov/tmp/mapserver/>> but with <!--
>         MapServer
>          >> Template --> on top.
>          >> CC
>          >> On Thu, May 4, 2023 at 12:32 PM Chris Cantey
>         <cantey0701 at gmail.com <mailto:cantey0701 at gmail.com>
>          >> <mailto:cantey0701 at gmail.com <mailto:cantey0701 at gmail.com>>>
>         wrote:
>          >>     I need that t-shirt! The quotes are in the mapfile, I
>         think gmail
>          >>     just hyperlinked the string.
>          >>     I am kind of testing 2 ways: Using the browser(a few
>         methods there),
>          >>     using linux: mapserv
>         "QUERY_STRING=map=/home/map=home/gis/tmp/mapserver/mapserver.map"
>          >>     When I do that, I still get a validation error:
>          >>     [Thu May  4 12:18:06 2023].428388 loadParams() QUERY_STRING:
>          >>     [Thu May  4 12:18:06 2023].428506 msCGILoadMap(): Web
>         application
>          >>     error. CGI variable "map" fails to validate.
>          >>     I'm wondering on the front end if there's a projection
>         issue, I see
>          >>     green network activity:
>          >>     On Thu, May 4, 2023 at 12:29 PM Jeff McKenna
>         <mailto:jmckenna at gatewaygeomatics.com>>> wrote:
>          >>         Also, your onlineresource is missing quotes, such as:
>          >>         "wms_onlineresource"
>         "https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map> <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map>>"
>          >>         -jeff
>          >>         --         Jeff McKenna
>          >>         GatewayGeo: Developers of MS4W, MapServer Consulting
>         and Training
>          >>         co-founder of FOSS4G
>          >> http://gatewaygeo.com/ <http://gatewaygeo.com/>
>         <http://gatewaygeo.com/ <http://gatewaygeo.com/>>
>          >>         On 2023-05-04 2:13 p.m., Jeff McKenna wrote:
>          >>          > Thanks.  I think you solved any validation issues
>         ( this
>          >>         request would
>          >>          > not validate, for example :
>         https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map> <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map <https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map>> )   so it's something else, very minor likely (I've got that t-shirt too, ha)
>          >>          > -jeff
>          >>          > On 2023-05-04 2:00 p.m., Chris Cantey wrote:
>          >>          >> Thanks, Jeff.. I found that out, thanks.
>          >>          >> I will work down from your points.
>          >>          >> Besc,
>          >>          >> On Thu, May 4, 2023 at 11:57 AM Jeff McKenna
>          >>          >> <jmckenna at gatewaygeomatics.com
>         <mailto:jmckenna at gatewaygeomatics.com>>>>
>          >>          >> wrote:
>          >>          >>     Also note, that the regular expression "^"
>         trick applies
>          >>         to the
>          >>          >>     MS_MAP_PATTERN in the config file (not the
>         MS_ERRORFILE
>          >>         path in the
>          >>          >>     mapfile).
>          >>          >>     Thanks for using MapServer Chris,
>          >>          >>     -jeff
>          >>          >>     --     Jeff McKenna
>          >>          >>     GatewayGeo: Developers of MS4W, MapServer
>         Consulting and
>          >>         Training
>          >>          >>     co-founder of FOSS4G
>          >>          >> http://gatewaygeo.com/ <http://gatewaygeo.com/>
>         <http://gatewaygeo.com/ <http://gatewaygeo.com/>>>
>          >>          >>     On 2023-05-04 1:48 p.m., Jeff McKenna wrote:
>          >>          >>      > More points for your consideration:
>          >>          >>      > - make sure all layers have a PROJECTION
>         object
>          >>          >>      > - remove any old references to the
>          >>         (non-standard/non-existing)
>          >>          >>      > EPSG:900913, replace with EPSG:3857  (see
>          >> https://epsg.io/3857 <https://epsg.io/3857>
>         <https://epsg.io/3857 <https://epsg.io/3857>>
>          >>          >>     <https://epsg.io/3857 <https://epsg.io/3857>
>         <https://epsg.io/3857 <https://epsg.io/3857>>> )
>          >>          >>      > - remove all warnings from your
>         GetCapabilities
>          >>         response, every
>          >>          >>     single
>          >>          >>      > warning, there should be no warnings in
>         the response,
>          >>         before you
>          >>          >>     move to
>          >>          >>      > testing GetMap requests
>          >>          >>      > - if you have PostGIS/db connections,
>         consider
>          >>         setting EXTENT
>          >>          >> at the
>          >>          >>      > layer-level, to improve speed for your
>         clients (review
>          >>          >>     optimizations at
>         https://mapserver.org/optimization/vector.html
>         <https://mapserver.org/optimization/vector.html>
>         <https://mapserver.org/optimization/vector.html>>
>         <https://mapserver.org/optimization/vector.html>>> )
>          >>          >>      > - during GetMap testing, comment any
>         TEMPLATE params
>          >>         in mapfile
>          >>          >>      > -jeff
>          >>          >>     _______________________________________________
>          >>          >>     MapServer-users mailing list
>          >>          >> MapServer-users at lists.osgeo.org
>         <mailto:MapServer-users at lists.osgeo.org>
>         <mailto:MapServer-users at lists.osgeo.org>>
>          >>          >> <mailto:MapServer-users at lists.osgeo.org
>         <mailto:MapServer-users at lists.osgeo.org>>>
>         https://lists.osgeo.org/mailman/listinfo/mapserver-users
>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>>
>         <https://lists.osgeo.org/mailman/listinfo/mapserver-users>>>
>          >>          >> Chris Cantey
>          >>          >> geo-odyssey.com <http://geo-odyssey.com>
>         <http://geo-odyssey.com <http://geo-odyssey.com>>
>         <http://geo-odyssey.com <http://geo-odyssey.com>>>
>          >>     --     Chris Cantey
>          >> Chris Cantey
>         Jeff McKenna
>         GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>     Chris Cantey
> Chris Cantey
Jeff McKenna
More information about the MapServer-users mailing list
