[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 4 11:19:37 PDT 2023
Yes, first get your mapfile image working with map2img, then move to
GetCapabilities request, remove warnings from it, then try a GetMap
request.  (this are always my steps, when creating mapfiles)
An empty map image usually means that MapServer is drawing from the
MAP-level extent that you set, but you may have the source projection
(at the layer-level) incorrect.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-05-04 3:09 p.m.,
> Its just a single white png though.
More information about the MapServer-users mailing list
