[MapServer-users] msWMSDispatch(): WMS server error. WMS request not enabled. Check wms/ows_enable_request settings.
Chris Cantey cantey0701 at gmail.com
Fri May 5 07:05:52 PDT 2023
That did it Jeff!
#getcapabilities
https://dev.gis.lcc.mn.gov/cgi-bin/mapserv?map=/home/web/gis/tmp/mapserver/mapserver.map&SERVICE=WMS&REQUEST=GetCapabilities&VERSION=1.3.0
Which returned: https://pastebin.com/xBJCbKGz (space in MAP>NAME, ie
"probably something small:D)
I fixed the warning, and voila!
Thanks for your help!
On Thu, May 4, 2023 at 1:19 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Yes, first get your mapfile image working with map2img, then move to
> GetCapabilities request, remove warnings from it, then try a GetMap
> request.  (this are always my steps, when creating mapfiles)
> An empty map image usually means that MapServer is drawing from the
> MAP-level extent that you set, but you may have the source projection
> (at the layer-level) incorrect.
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2023-05-04 3:09 p.m.,
> > Its just a single white png though.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Chris Cantey
geo-odyssey.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230505/756955f9/attachment.htm>
More information about the MapServer-users mailing list
