[MapServer-users] msLoadConfig error on Ubuntu 23.04
Frank Sokolic sokolic at worldonline.co.za
Wed May 17 08:11:04 PDT 2023
Hi Jörg,
Thanks for your advice. Setting the config file in the apache-config
worked and now MapServer is working.
Now I can carry on developing my project :-)
Frank.
On 2023/05/17 15:08, Jörg Thomsen (WhereGroup) wrote:
> Hello Frank,
>>> Is there anything obvious I'm doing wrong?
> no....
> have you checked whether the variable is really set with the correct
> name and value/path+filename?
> -> printenv | grep 'MAPSERVER'
> I remember a few times MapServer needed +RW instead of +R
> Usually I don't use system variables, for me it works fine setting the
> config-file in the apache-config like
> SetEnv MAPSERVER_CONFIG_FILE /data/config/mapserver/mapserver.conf
> FcgidInitialEnv MAPSERVER_CONFIG_FILE
> (depending on cgi / fcgi)
> Jörg
> Am 17.05.23 um 12:39 schrieb Frank Sokolic:
>> Hi MapServer users,
>> I'm having problems getting MapServer 8 to read the conf file on my
>> Ubuntu 23.04 Lunar Lobster machine. I installed MapServer using the
>> command "sudu apt install cgi-mapserver" and this installs
>> 8.0.0-3build2. However, when I test the installation I get an error:
>> "msLoadConfig(): Unable to access file. See
>> mapserver.org/config_file.html for more information."
>> I have created a conf file that looks like this:
>> CONFIG
>>    MAPS
>>      ECSRP_MAPFILE "/var/www/ecsrp/mapfiles/ecsrp.map"
>>    END
>> END
>> I have created a system-wide environment variable pointing to the
>> conf file:
>> MAPSERVER_CONFIG_FILE=/usr/local/etc/mapserver.conf
>> I have granted read access to Owner/Group/Others on both
>> mapserver.conf and ecsrp.map but still get the msLoadConfig() error.
>> Regards, Frank.
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
