[MapServer-users] msLoadConfig error on Ubuntu 23.04
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Wed May 17 06:08:03 PDT 2023
Hello Frank,
>> Is there anything obvious I'm doing wrong?
no....
have you checked whether the variable is really set with the correct
name and value/path+filename?
-> printenv | grep 'MAPSERVER'
I remember a few times MapServer needed +RW instead of +R
Usually I don't use system variables, for me it works fine setting the
config-file in the apache-config like
SetEnv MAPSERVER_CONFIG_FILE /data/config/mapserver/mapserver.conf
FcgidInitialEnv MAPSERVER_CONFIG_FILE /data/config/mapserver/mapserver.conf
(depending on cgi / fcgi)
Jörg
Am 17.05.23 um 12:39 schrieb Frank Sokolic:
> Hi MapServer users,
> I'm having problems getting MapServer 8 to read the conf file on my
> Ubuntu 23.04 Lunar Lobster machine. I installed MapServer using the
> command "sudu apt install cgi-mapserver" and this installs
> 8.0.0-3build2. However, when I test the installation I get an error:
> "msLoadConfig(): Unable to access file. See
> mapserver.org/config_file.html for more information."
> I have created a conf file that looks like this:
> CONFIG
>    MAPS
>      ECSRP_MAPFILE "/var/www/ecsrp/mapfiles/ecsrp.map"
>    END
> END
> I have created a system-wide environment variable pointing to the conf
> file:
> MAPSERVER_CONFIG_FILE=/usr/local/etc/mapserver.conf
> I have granted read access to Owner/Group/Others on both mapserver.conf
> and ecsrp.map but still get the msLoadConfig() error.
> Regards, Frank.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users mailing list
