[MapServer-users] Docker image for MapServer with PHP-MapScript
Jan Hartmann
j.l.h.hartmann at gmail.com
Wed Nov 8 05:59:54 PST 2023
Thanks Steve. I should have been able to guess that, but the
PHP-MapScript documentation
(https://mapserver.org/mapscript/php/index.html) still has a metadata
member for the MapObj. As well as for the WebObj
As has been said before, the documentation for PHP Mapscript
(https://mapserver.org/mapscript/php/index.html) is not very helpful.
Essentially, it still describes the pre-SWIG version. I have been
compiling MapServer since before the first marvelous MapServer-meeting
in 2003 (https://maps.hisgis.nl/conferences/2003/mum/, look at the
photographs!), but I have been using the UbuntuGIS version for the last
few years. It was really a pain to get the current version working from
scratch in a user directory. I was almost starting to think about
switching to GeoServer :-). To get the "official" PHP-Mapscript-guide
working I had to use:
https://ms4w.com/trac/wiki/MigrationGuide5.x
https://mapserver.org/MIGRATION_GUIDE.html
https://mapserver.org/mapscript/php/migration_guide.html
The main new requirements (including mapscript.php and setting
mapserver.conf) core-dump the PHP-script when missing, so that too leads
to some not-so-nice debugging. I would strongly advise to bring the
documentation of MapScript up to date and to base it on the most recent
version. And to clean out a bit the remnants of previous releases.
There seems to be a working Docker-version for MapServer/Mapscript in
Debian Bookworm
(https://lists.osgeo.org/pipermail/mapserver-dev/2023-October/017032.html),
but I haven't tested it yet. Has anyone worked with it? And does anyone
know of a recent Docker version for Mapserver/Mapscript in Alpine? Some
organisations I am working for in the Euregio Aachen-Liege-Maastricht
require Alpine for their Docker version.
Anyway, thanks to Tanya, Vassilis and Steve,
Jan Hartmann
Amsterdam
On 30/10/2023 18:56, Lime, Steve D (MNIT) wrote:
> Map-level metadata lives in the WEB object…
> *From:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *On
> Behalf Of *Jan Hartmann via MapServer-users
> *Sent:* Monday, October 30, 2023 12:46 PM
> *To:* Vassilis Chatzigiannakis <vchatzi at itml.gr>;
> mapserver-users at lists.osgeo.org
> *Subject:* Re: [MapServer-users] Docker image for MapServer with
> PHP-MapScript
> Almost there. There are additional migration examples in:
> I wrote wrapper functions for the old ms_new... functions, and can
> create that way a new mapObj called $oMap.
> The "set" function has been renamed to "__set" : not
> $oMap->set("maxsize",6020), but: ;$oMap->__set("maxsize",6020);
> Layers can be declared as before: $layer = $oMap->getLayer(1).
> Metadata have to be set as follows:
> Not: $layer->setMetadata("...","..."); but:
> $layer->metadata->set("...","...")
> However, I cannot set the metadata of the mapObj:
> $oMap->metadata->set("...","...") gives: "Undefined array key "metadata""
> Any idea?
> On 29/10/2023 07:52, Vassilis Chatzigiannakis wrote:
> Yes the documentation is a mess .
> I worked with this reference:
> https://mapserver.org/mapscript/mapscript-api/index.html
> So, you start by
> $oMap= newmapObj($mapfile);
> Best regards,
> Vassilis
> *From:* Jan Hartmann <j.l.h.hartmann at gmail.com>
> <mailto:j.l.h.hartmann at gmail.com>
> *Sent:* Saturday, October 28, 2023 9:14 PM
> <mailto:vchatzi at itml.gr>; mapserver-users at lists.osgeo.org
> PHP-MapScript
> This seems to work. And it says so in the migration guide
> (https://mapserver.org/mapscript/php/migration_guide.html):
> all of your PHP scripts (that leverage MapServer objects and
> functions) must now always first include the generated
> mapscript.php file containing MapServer constants:
> But could it be that only "$m = new mapObj('...');" is accepted,
> and "$m=ms_newMapObj('...');" isn't? The docs still mention the
> old call (https://mapserver.org/mapscript/php/phpmapscript.html
> On 28/10/2023 09:11, Vassilis Chatzigiannakis wrote:
> Hi,
> I did it recently. There should be a mapscript.php file in the
> same folder as the php_mapscriptng.so extension.
> You need to include it in your php script.
> Best,
> Vassilis
> <mailto:mapserver-users-bounces at lists.osgeo.org> *On Behalf Of
> *Sent:* Friday, October 27, 2023 9:42 PM
> *To:* mapserver-users at lists.osgeo.org
> with PHP-MapScript
> I made a docker version of mapserver/php-mapscript myself,
> based on Ubuntu 22.04. I installed all required libraries with
> apt, and compiled mapserver and mapscript according to
> instructions. No problem at all.
> At the end I got the following from phpinfo();
> mapscript
> *MapServer Version*
> MapServer version 8.0.1 PROJ version 9.3 GDAL version 3.4
> OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=GEOS
> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> INPUT=FLATGEOBUF
> But no mapscript function or object was regognized in my
> PHP-scripts:
> PHP Fatal error: Uncaught Error: Class "mapObj" not found in
> /virdir/www_root/test.php:2
> Stack trace:
> #0 {main}
> thrown in /virdir/www_root/test.php on line 2
> I am really desparate. Has anyone ever succeeded to get
> php_mapscriptng.so to work? Or does anyone know of a working
> Docker image for MapServer with PHP MapScript?
> Jan
> On 21/10/2023 05:40, Jan Hartmann wrote:
> I tried this with serveral versions of PHP and MapServer,
> but got always the same result. Can anyone point me to a
> Docker image for MapServer + PHP-MapScript?
> Jan
> On 19/10/2023 18:12, Jan Hartmann wrote:
> Still not there. Everything has been installed, and
> phpinfo() gives:
> *MapServer Version*
> 3.7 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=OGCAPI_SERVER INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
> But calling "$map = new mapObj('mapfile.map');" gives:
> *Fatal error*: Uncaught Error: Class "mapObj" not
> found in
> /mnt/virdir/www_root/test/test_mapscript.php:2 Stack
> trace: #0 {main} thrown in
> */mnt/virdir/www_root/test/test_mapscript.php* on line *2
> *Any idea?
> Jan
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231108/eca24c51/attachment-0001.htm>
More information about the MapServer-users
