[MapServer-users] strrstr error occure
Even Rouault even.rouault at spatialys.com
Mon Nov 27 07:16:06 PST 2023
You didn't mention which operating system you use. I assume this is
Debian or Ubuntu from the reported paths.
Have a look at
https://github.com/MapServer/MapServer/blob/b43fd4f2a5edb0e1f882ff256c257ad5c5c44930/ci/travis/before_install.sh#L15
for the dependencies you need to install. In your case  from the error
messages, what is missing is: protobuf-c-compiler,
libprotobuf-c-dev,libfcgi-dev
Le 27/11/2023 à 16:10, Raivo Rebane a écrit :
> Hi,
> here is output of cmake :
> raivo at Hydra:~$ cd mapserver-8.0.1/
> raivo at Hydra:~/mapserver-8.0.1$ cd build/
> raivo at Hydra:~/mapserver-8.0.1/build$ cmake ..
> -- Requiring C++11
> -- Requiring C++11 - done
> -- Requiring C99
> -- Requiring C99 - done
> -- Could NOT find ProtobufC (missing: PROTOBUFC_LIBRARY
> PROTOBUFC_COMPILER PROTOBUFC_INCLUDE_DIR)
> CMake Error at CMakeLists.txt:93 (message):
>   PROTOBUFC library/component/dependency could not be found.
>     HINTS:
>     - disable PROTOBUFC support by adding -DWITH_PROTOBUFC=0
>     - add the PROTOBUFC install directory to the CMAKE_PREFIX_PATH
> variable
> (-DCMAKE_PREFIX_PATH="/path/to/PROTOBUFC-install-dir;/path/to/other/dirs"
> Call Stack (most recent call first):
>   CMakeLists.txt:339 (report_optional_not_found)
> -- Found Proj 9.4
> -- Could NOT find FCGI (missing: FCGI_LIBRARY FCGI_INCLUDE_DIR)
>   FCGI library/component/dependency could not be found.
>     HINTS:
>     - disable FCGI support by adding -DWITH_FCGI=0
>     - add the FCGI install directory to the CMAKE_PREFIX_PATH variable
> (-DCMAKE_PREFIX_PATH="/path/to/FCGI-install-dir;/path/to/other/dirs"
>   CMakeLists.txt:598 (report_optional_not_found)
> -- * Summary of configured options for this build
> --  * Mandatory components
> --   * GDAL: /usr/local/lib/libgdal.so
> --   * PROJ: /usr/local/lib/libproj.so
> --   * png: /usr/lib/x86_64-linux-gnu/libpng.so
> --   * jpeg: /usr/lib/x86_64-linux-gnu/libjpeg.so
> --   * freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so
> --  * Optional components
> --   * GIF: /usr/lib/x86_64-linux-gnu/libgif.so
> --   * MYSQL: disabled
> --   * FRIBIDI: /usr/lib/x86_64-linux-gnu/libfribidi.so
> --   * HARFBUZZ: /usr/lib/x86_64-linux-gnu/libharfbuzz.so
> --   * CAIRO: /usr/lib/x86_64-linux-gnu/libcairo.so
> --   * SVGCAIRO: disabled
> --   * RSVG: disabled
> --   * CURL: disabled
> --   * PIXMAN: disabled
> --   * LIBXML2: /usr/lib/x86_64-linux-gnu/libxml2.so
> --   * POSTGIS: /usr/lib/libpq.so
> --   * GEOS: /usr/local/lib/libgeos_c.so
> --   * FastCGI: disabled
> --   * PROTOBUFC: disabled
> --   * Oracle Spatial: disabled
> --   * Exempi XMP: disabled
> --  * Optional features
> --   * WMS SERVER: ENABLED
> --   * WFS SERVER: ENABLED
> --   * WCS SERVER: ENABLED
> --   * SOS SERVER: disabled
> --   * OGCAPI SERVER: ENABLED
> --   * WMS CLIENT: disabled
> --   * WFS CLIENT: disabled
> --   * ICONV: ENABLED
> --   * Thread-safety support: disabled
> --   * KML output: disabled
> --   * XML Mapfile support: disabled
> --  * Mapscripts
> --   * Python: disabled
> --   * PHPNG: disabled
> --   * PERL: disabled
> --   * RUBY: disabled
> --   * JAVA: disabled
> --   * C#: disabled
> --   * V8 Javascript: disabled
> --   * Apache Module (Experimental): disabled
> --   * Python MapScript Annotations: disabled
http://www.spatialys.com
More information about the MapServer-users mailing list
