[MapServer-users] strrstr error occure
Raivo Rebane raivo at r-systems.ee
Mon Nov 27 07:10:24 PST 2023
here is output of cmake :
raivo at Hydra:~$ cd mapserver-8.0.1/
raivo at Hydra:~/mapserver-8.0.1$ cd build/
raivo at Hydra:~/mapserver-8.0.1/build$ cmake ..
-- Requiring C++11
-- Requiring C++11 - done
-- Requiring C99
-- Requiring C99 - done
-- Could NOT find ProtobufC (missing: PROTOBUFC_LIBRARY
PROTOBUFC_COMPILER PROTOBUFC_INCLUDE_DIR)
CMake Error at CMakeLists.txt:93 (message):
   PROTOBUFC library/component/dependency could not be found.
     HINTS:
     - disable PROTOBUFC support by adding -DWITH_PROTOBUFC=0
     - add the PROTOBUFC install directory to the CMAKE_PREFIX_PATH
variable
(-DCMAKE_PREFIX_PATH="/path/to/PROTOBUFC-install-dir;/path/to/other/dirs"
Call Stack (most recent call first):
   CMakeLists.txt:339 (report_optional_not_found)
-- Found Proj 9.4
-- Could NOT find FCGI (missing: FCGI_LIBRARY FCGI_INCLUDE_DIR)
   FCGI library/component/dependency could not be found.
     HINTS:
     - disable FCGI support by adding -DWITH_FCGI=0
     - add the FCGI install directory to the CMAKE_PREFIX_PATH variable
(-DCMAKE_PREFIX_PATH="/path/to/FCGI-install-dir;/path/to/other/dirs"
   CMakeLists.txt:598 (report_optional_not_found)
-- * Summary of configured options for this build
--  * Mandatory components
--   * GDAL: /usr/local/lib/libgdal.so
--   * PROJ: /usr/local/lib/libproj.so
--   * png: /usr/lib/x86_64-linux-gnu/libpng.so
--   * jpeg: /usr/lib/x86_64-linux-gnu/libjpeg.so
--   * freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so
--  * Optional components
--   * GIF: /usr/lib/x86_64-linux-gnu/libgif.so
--   * MYSQL: disabled
--   * FRIBIDI: /usr/lib/x86_64-linux-gnu/libfribidi.so
--   * HARFBUZZ: /usr/lib/x86_64-linux-gnu/libharfbuzz.so
--   * CAIRO: /usr/lib/x86_64-linux-gnu/libcairo.so
--   * SVGCAIRO: disabled
--   * RSVG: disabled
--   * CURL: disabled
--   * PIXMAN: disabled
--   * LIBXML2: /usr/lib/x86_64-linux-gnu/libxml2.so
--   * POSTGIS: /usr/lib/libpq.so
--   * GEOS: /usr/local/lib/libgeos_c.so
--   * FastCGI: disabled
--   * PROTOBUFC: disabled
--   * Oracle Spatial: disabled
--   * Exempi XMP: disabled
--  * Optional features
--   * WMS SERVER: ENABLED
--   * WFS SERVER: ENABLED
--   * WCS SERVER: ENABLED
--   * SOS SERVER: disabled
--   * OGCAPI SERVER: ENABLED
--   * WMS CLIENT: disabled
--   * WFS CLIENT: disabled
--   * ICONV: ENABLED
--   * Thread-safety support: disabled
--   * KML output: disabled
--   * XML Mapfile support: disabled
--  * Mapscripts
--   * Python: disabled
--   * PHPNG: disabled
--   * PERL: disabled
--   * RUBY: disabled
--   * JAVA: disabled
--   * C#: disabled
--   * V8 Javascript: disabled
--   * Apache Module (Experimental): disabled
--   * Python MapScript Annotations: disabled
-- PROJECT_BINARY_DIR is set to /home/raivo/mapserver-8.0.1/build
-- Will install files to /usr/local
-- Will install libraries to /usr/local/lib
-- Configuring incomplete, errors occurred!
See also "/home/raivo/mapserver-8.0.1/build/CMakeFiles/CMakeOutput.log".
See also "/home/raivo/mapserver-8.0.1/build/CMakeFiles/CMakeError.log".
Raivo
On 27.11.23 14:28, Even Rouault wrote:
> Hi,
>>  want to test of use the mapserver, but on insatllation I got errors :
>> /usr/bin/ld: CMakeFiles/cmTC_e57a2.dir/CheckFunctionExists.c.o: in
>> function `main':
>> CheckFunctionExists.c:(.text+0x14): undefined reference to `strrstr'
>> collect2: error: ld returned 1 exit status
>> make[1]: *** [CMakeFiles/cmTC_e57a2.dir/build.make:87: cmTC_e57a2]
>> Error 1
>> What's wrong ?
> Assuming this is not an error when building mapserver itself, but when
> just running cmake, such errors in CMakeOutput.log or CMakeError.log
> are totally legitimate. This is just CMake testing which features are
> available in your environments, and to do so it tries to build some
> small source files, and compilation errors are expected when the
> feature is not available.
> Even
More information about the MapServer-users mailing list
