[MapServer-users] How to format labels on contours
Seth G sethg at geographika.co.uk
Sat Oct 21 00:04:51 PDT 2023
The MapScript API docs are back online - see https://mapserver.org/mapscript/mapscript-api/stub/mapscript.classObj.html#mapscript.classObj
The setText() method should give you what you need. Example (using Python):
s = mapscript.classObj(layer)
# other style and label stuff
s.setText('(tostring(([SQKM]),"%.0f")+" km2")')
# check the output using
print(s.convertToString())
When using updateFromString it will replace everything in the classObj hence the error.
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Fri, Oct 20, 2023, at 9:16 PM, Trygve Aspenes via MapServer-users wrote:
> Hi
> So I have made a contour plot from a raster. Works nicely.
> Then I added labels to give context to the contours. Fine.
> Now I want to format the labels.
> I have found this post
> https://gis.stackexchange.com/questions/350089/round-number-for-label-in-mapserver
> suggesting a syntax:
> TEXT (tostring(([SQKM]),"%.0f")+" km2")
> Nice, but I use mapscript. And I do not understand nor find any examples
> how I could do this with mapscript
> I tried with:
> <other style and label stuff>
> s.updateFromString('TEXT (tostring(([SQKM]),"%.0f")+" km2")')
> But I get:
> EOFError: loadClass(): Premature End-of-File.
> So obviously not correct.
> Is there someone who could suggest what could be wrong here or what else
> to look at and try?
> Trygve Aspenes
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
