[MapServer-users] Silent error running mapserver
Seth G sethg at geographika.co.uk
Fri Sep 15 00:02:41 PDT 2023
How are you setting your "PROJ_LIB" path? It looks like it can't find the Proj SHARE directory.
Are you able to share a Mapfile? Maybe try with a cut-down version - there are lots of custom parameters in your querystring (that shouldn't affect things, but a simpler test case would be easier to debug).
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Thu, Sep 14, 2023, at 4:05 PM, Troels Arvin wrote:
> Hello,
> I'm struggling to find out why my newly compiled Mapserver 8 exits without any output and without any error messages.
> Using Mapserver 6, the following command resulted in PNG output.
> /usr/local/bin/mapserv QUERY_STRING="map=/foo/my.map&min_x_wc=545984&min_y_wc=6283731.2&max_x_wc=547622.4&max_y_wc=6285369.600000001&layers=theme1&phaseid=00000000-0000-0000-0000-000000000000&elementtypekeys=''&service=WMS&srs=EPSG:25832&workspaceid=66ddb06f-0527-4dc8-89db-d8ed3edf10b3&profileid=00000000-0000-0000-0000-000000000000&_olsalt=0.5323379383513367&width=256&bbox=XXX,XXX,XXX,XXX&height=256&transparent=TRUE&request=GetMap&version=1.1.1&format=image/png&draftid=00000000-0000-0000-0000-000000000000&foo=bar"
> But using Mapserver 8, nothing happens. On the command line, the result code of the command is 0.
> Using strace, the last activities look like this:
> 710989 read(3, "ass\n      name \"9.26_0\"\n      expression ('[elementtypekey]' = '9.26_0' )\n\n      style\n symbo"..., 8192) = 8192
> 710989 access("/home/foo at bar.org", W_OK) = 0
> 710989 openat(AT_FDCWD, "/home/foo at bar.org/.local/share/proj/epsg", O_RDONLY) = -1 ENOENT (No such file or directory)
> 710989 openat(AT_FDCWD, "/usr/share/proj/epsg", O_RDONLY) = 5
> 710989 close(5)                         = 0
> 710989 close(3)                         = 0
> 710989 newfstatat(AT_FDCWD, "/usr/share/proj/proj.db", {st_mode=S_IFREG|0644, st_size=7921664, ...}, 0) = 0
> 710989 newfstatat(4, "", {st_mode=S_IFREG|0644, st_size=7921664, ...}, AT_EMPTY_PATH) = 0
> 710989 close(4)                         = 0
> 710989 munmap(0x7fc8a3d03000, 135168)   = 0
> 710989 munmap(0x7fc8a3d24000, 258048)   = 0
> 710989 exit_group(0)                    = ?
> 710989 +++ exited with 0 +++
> Output from "mapserv -v":
> MapServer version 8.0.1 PROJ version 6.3 GDAL version 3.4 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
> Any ideas?
> Kind regards,
> Troels Arvin
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20230915/ed1b552f/attachment.htm>
More information about the MapServer-users mailing list
