[MapServer-users] Silent error running mapserver
Troels Arvin troels at arvin.dk
Mon Sep 18 08:30:27 PDT 2023
Hello,
Seth G wrote:
> Are you able to share a Mapfile? Maybe try with a cut-down version
I found out things seem to fail due to a FILTER expression in the map
file which result in an "... AND ()" clause to be added to the SQL being
sent to the database (which is a syntax error, at least in Postgres).
My issue seems to have to do with the change from 6 to 7 where:
" Note Until MapServer 6, native filters could be specified as:
   FILTER 'where id=234'.
   But this is no longer supported."
(From https://mapserver.org/mapfile/layer.html )
The odd thing is we have Windows Mapserver 7 where the map files are
still working. Mapserver would be completely similar regarding map file
rules, regardless of operating system, I'd assume.
Troels
More information about the MapServer-users mailing list
