[MapServer-users] Silent error running mapserver
Seth G sethg at geographika.co.uk
Mon Sep 18 14:06:54 PDT 2023
Mapfiles are very portable between operating systems, with some possible edge cases as dependencies such as the regex library may vary, or a different code path is used on Windows which may render something slightly differently, or produce different line endings.
It is more likely something changed between MapServer 7 and 8 which would cause this to break, possibly the change here [1]. It does sound like a bug though if an invalid SQL statement is created, and if a test case can be created it would be good to open an issue.
In any case it is best to update to the new PROCESSING 'NATIVE_FILTER=id=234' format for Mapfiles in MapServer 8.0.
Seth
[1] https://github.com/MapServer/MapServer/blob/6991fd2d2b21270e9368b52526a89a0204c2399b/src/mappostgis.cpp#L2012
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Mon, Sep 18, 2023, at 5:30 PM, Troels Arvin wrote:
> Hello,
> Seth G wrote:
>> Are you able to share a Mapfile? Maybe try with a cut-down version
> I found out things seem to fail due to a FILTER expression in the map
> file which result in an "... AND ()" clause to be added to the SQL being
> sent to the database (which is a syntax error, at least in Postgres).
> My issue seems to have to do with the change from 6 to 7 where:
> " Note Until MapServer 6, native filters could be specified as:
>    FILTER 'where id=234'.
>    But this is no longer supported."
> (From https://mapserver.org/mapfile/layer.html )
> The odd thing is we have Windows Mapserver 7 where the map files are
> still working. Mapserver would be completely similar regarding map file
> rules, regardless of operating system, I'd assume.
> Troels
More information about the MapServer-users mailing list
