[MapServer-users] Mapserver>=8.0: Layer Composite Opacity
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Aug 7 07:54:44 PDT 2024
Hi Dieter,
I also just used MS4W's PHP (PHP version 8.3.9) to call the setOpacity()
function, to update the layer's opacity, such as:
   $oPolyLayer->setOpacity(40);
(see sample script at https://ms4w.com/trac/wiki/SWIGMapScriptOpacity )
-jeff
On 2024-08-07 11:38 a.m., Jeff McKenna via MapServer-users wrote:
> Hi Dieter,
> It could be possible that your MapServer installation was compiled with
> Pixman library support enabled in MapServer, which unfortunately causes
> a known bug where opacity does not work (see
> https://github.com/MapServer/MapServer/issues/5343 ).  I believe we
> should completely remove Pixman support from MapServer in a future
> release, as so many users hit this issue each year.
> In other words, make sure that you set -DWITH_PIXMAN=0 when compiling
> MapServer from source.
> PS. I actually used the small mapfile included in that ticket, for
> testing now with today's MapServer 8.3-dev on MS4W 5, on Windows, and
> successfully generated a proper map image (with opacity) with map2img.
> thanks,
> -jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-users mailing list
