[MapServer-users] Mapserver>=8.0: Layer Composite Opacity
GOGIS Dieter Zuberbühler
dieter.zuberbuehler at gogis.ch
Wed Aug 7 08:04:24 PDT 2024
Hi Jeff,
many thanks for this hint. -DWITH_PIXMAN=0 fixed it!
Best regards,
Dieter
On Wed, 2024-08-07 at 11:38 -0300, Jeff McKenna via MapServer-users
wrote:
> Hi Dieter,
> It could be possible that your MapServer installation was compiled
> with
> Pixman library support enabled in MapServer, which unfortunately
> causes
> a known bug where opacity does not work (see
> https://github.com/MapServer/MapServer/issues/5343 ). I believe we
> should completely remove Pixman support from MapServer in a future
> release, as so many users hit this issue each year.
> In other words, make sure that you set -DWITH_PIXMAN=0 when compiling
> MapServer from source.
> PS. I actually used the small mapfile included in that ticket, for
> testing now with today's MapServer 8.3-dev on MS4W 5, on Windows, and
> successfully generated a proper map image (with opacity) with
> map2img.
> thanks,
> -jeff
GOGIS GmbH
Rosenstrasse 2
CH-4142 Münchenstein
Tel. +4144 586 60 15
Mob. +4178 619 98 91
www.gogis.ch
More information about the MapServer-users
