[MapServer-users] CGI variable "map" fails to validate
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Wed Feb 7 00:23:32 PST 2024
I'm not sure whether the pattern is correct. Shouldn't ist start with ^?
Have yout tried
MS_MAP_PATTERN '.'? (not for production, just as a test)
Jörg
Am 06.02.24 um 20:12 schrieb Lernout, Matthew via MapServer-users:
> Hi,
> Having trouble making requests since updating to 8.0.1 from 7.6.2.
> Mapserver is running in IIS using FastCGI and the configuration steps
> from: https://mapserver.org/installation/iis.html
> <https://mapserver.org/installation/iis.html>
> A new config file was added to the filesystem and server Environment
> variables as per documented requirements added since 7.6.3, but having
> trouble validating any map arguments. All requests return the error "CGI
> variable "map" fails to validate" even though regexp should pass based
> on expression tests.
> Here is the full config file in use:
> CONFIG
>    ENV
>      MS_MAP_PATTERN "\.map$"
>      PROJ_LIB "F:/MapServer/bin/proj7/SHARE"
>      CURL_CA_BUNDLE "F:\MapServer\bin\curl\curl-ca-bundle.crt"
>    END
>    PLUGINS
>      "mssql" "F:/MapServer/bin/ms/plugins/mssql2008/msplugin_mssql2008.dll"
>      "oci" "F:/MapServer/bin/ms/plugins/oci/msplugin_oracle.dll"
>    END
> END
> The current MS_MAP_PATTERN is just a simplified test to confirm 8.0.1
> working before I update to the real regexp, and my understanding is it
> should map anything that ends in .map? But every map argument I throw in
> (including verified working arguments for 7.6.2) result in a failure to
> validate. Are there other crucial configurations missing that are
> necessary to pass validation?
> Thanks,
> Matt
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com/
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users mailing list
