[MapServer-users] CGI variable "map" fails to validate
    Lernout, Matthew
    Matt.Lernout at stantec.com
    Wed Feb  7 08:33:16 PST 2024
MS_MAP_PATTERN '.' also results in the same failed validation error, which is what makes me think the issue may be with another config setting. '.' should match any input, right?
Just to make sure my config file was being loaded, I commented out the MS_MAP_PATTERN entry entirely, and got the error "msCGILoadMap(): Web application error. Required configuration value MS_MAP_PATTERN not set."
Matt
-----Original Message-----
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On Behalf Of Jörg Thomsen (WhereGroup) via MapServer-users
Sent: Wednesday, February 7, 2024 3:24 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [MapServer-users] CGI variable "map" fails to validate
[You don't often get email from mapserver-users at lists.osgeo.org. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
I'm not sure whether the pattern is correct. Shouldn't ist start with ^?
Have yout tried
MS_MAP_PATTERN '.'? (not for production, just as a test)
Jörg
Am 06.02.24 um 20:12 schrieb Lernout, Matthew via MapServer-users:
> Hi,
> Having trouble making requests since updating to 8.0.1 from 7.6.2.
> Mapserver is running in IIS using FastCGI and the configuration steps
> from:
> https://maps/
> erver.org%2Finstallation%2Fiis.html&data=05%7C02%7Cmatt.lernout%40stan
> tec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c219a469297d3f2b4d
> 80281e7%7C0%7C0%7C638428910243090792%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiM
> C4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C
> &sdata=dh%2BpgGwk5996f0GEMeX7O8rcv5J81TnPzeFNZ9XoVLs%3D&reserved=0
> <https://map/
> server.org%2Finstallation%2Fiis.html&data=05%7C02%7Cmatt.lernout%40sta
> ntec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c219a469297d3f2b4
> d80281e7%7C0%7C0%7C638428910243098246%7CUnknown%7CTWFpbGZsb3d8eyJWIjoi
> MC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7
> C&sdata=OIoWHSlKZJrXWspqwVfY5jhX4lzBcQuI%2Bw5IeOVtXBA%3D&reserved=0>
> A new config file was added to the filesystem and server Environment
> variables as per documented requirements added since 7.6.3, but having
> trouble validating any map arguments. All requests return the error
> "CGI variable "map" fails to validate" even though regexp should pass
> based on expression tests.
> Here is the full config file in use:
> CONFIG
>    ENV
>      MS_MAP_PATTERN "\.map$"
>      PROJ_LIB "F:/MapServer/bin/proj7/SHARE"
>      CURL_CA_BUNDLE "F:\MapServer\bin\curl\curl-ca-bundle.crt"
>    END
>    PLUGINS
>      "mssql" "F:/MapServer/bin/ms/plugins/mssql2008/msplugin_mssql2008.dll"
>      "oci" "F:/MapServer/bin/ms/plugins/oci/msplugin_oracle.dll"
>    END
> END
> The current MS_MAP_PATTERN is just a simplified test to confirm 8.0.1
> working before I update to the real regexp, and my understanding is it
> should map anything that ends in .map? But every map argument I throw
> in (including verified working arguments for 7.6.2) result in a
> failure to validate. Are there other crucial configurations missing
> that are necessary to pass validation?
> Thanks,
> Matt
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://list/
> s.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-users&data=05%7C02%7Cmatt
> .lernout%40stantec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c21
> 9a469297d3f2b4d80281e7%7C0%7C0%7C638428910243105153%7CUnknown%7CTWFpbG
> Zsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%
> 3D%7C0%7C%7C%7C&sdata=c%2BjBl2NTy%2BIZxCYZmp0CLwa2ujlD%2BC%2BfzzIQgXKw
> lyI%3D&reserved=0
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der http://www.foss-academy.com/
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
joerg.thomsen at wheregroup.com
http://www.wheregroup.com/
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
https://lists.osgeo.org/mailman/listinfo/mapserver-users
 Caution: This email originated from outside of Stantec. Please take extra precaution.
 Attention: Ce courriel provient de l'extérieur de Stantec. Veuillez prendre des précautions supplémentaires.
 Atención: Este correo electrónico proviene de fuera de Stantec. Por favor, tome precauciones adicionales.
More information about the MapServer-users
