[MapServer-users] CGI variable "map" fails to validate
Seth G sethg at geographika.co.uk
Wed Feb 7 08:48:27 PST 2024
Hi Matthew,
The CONFIG file I think is only reloaded when IIS or the Application Pool is restarted, so some changes to the regex may have been ignored.
Do you have a sample request with the &map= parameter? Is there anything in a web.config file that could be stripping these out or modifying them?
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Feb 7, 2024, at 5:33 PM, Lernout, Matthew via MapServer-users wrote:
> MS_MAP_PATTERN '.' also results in the same failed validation error,
> which is what makes me think the issue may be with another config
> setting. '.' should match any input, right?
> Just to make sure my config file was being loaded, I commented out the
> MS_MAP_PATTERN entry entirely, and got the error "msCGILoadMap(): Web
> application error. Required configuration value MS_MAP_PATTERN not set."
> Matt
> -----Original Message-----
> From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> On
> Behalf Of Jörg Thomsen (WhereGroup) via MapServer-users
> Sent: Wednesday, February 7, 2024 3:24 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [MapServer-users] CGI variable "map" fails to validate
> [You don't often get email from mapserver-users at lists.osgeo.org. Learn
> why this is important at https://aka.ms/LearnAboutSenderIdentification ]
> Hi,
> I'm not sure whether the pattern is correct. Shouldn't ist start with ^?
> Have yout tried
> MS_MAP_PATTERN '.'? (not for production, just as a test)
> Jörg
> Am 06.02.24 um 20:12 schrieb Lernout, Matthew via MapServer-users:
>> Hi,
>> Having trouble making requests since updating to 8.0.1 from 7.6.2.
>> Mapserver is running in IIS using FastCGI and the configuration steps
>> from:
>> https://maps/
>> erver.org%2Finstallation%2Fiis.html&data=05%7C02%7Cmatt.lernout%40stan
>> tec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c219a469297d3f2b4d
>> 80281e7%7C0%7C0%7C638428910243090792%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiM
>> C4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7C
>> &sdata=dh%2BpgGwk5996f0GEMeX7O8rcv5J81TnPzeFNZ9XoVLs%3D&reserved=0
>> <https://map/
>> server.org%2Finstallation%2Fiis.html&data=05%7C02%7Cmatt.lernout%40sta
>> ntec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c219a469297d3f2b4
>> d80281e7%7C0%7C0%7C638428910243098246%7CUnknown%7CTWFpbGZsb3d8eyJWIjoi
>> MC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C0%7C%7C%7
>> C&sdata=OIoWHSlKZJrXWspqwVfY5jhX4lzBcQuI%2Bw5IeOVtXBA%3D&reserved=0>
>> A new config file was added to the filesystem and server Environment
>> variables as per documented requirements added since 7.6.3, but having
>> trouble validating any map arguments. All requests return the error
>> "CGI variable "map" fails to validate" even though regexp should pass
>> based on expression tests.
>> Here is the full config file in use:
>> CONFIG
>>    ENV
>>      MS_MAP_PATTERN "\.map$"
>>      PROJ_LIB "F:/MapServer/bin/proj7/SHARE"
>>      CURL_CA_BUNDLE "F:\MapServer\bin\curl\curl-ca-bundle.crt"
>>    END
>>    PLUGINS
>>      "mssql" "F:/MapServer/bin/ms/plugins/mssql2008/msplugin_mssql2008.dll"
>>      "oci" "F:/MapServer/bin/ms/plugins/oci/msplugin_oracle.dll"
>>    END
>> END
>> The current MS_MAP_PATTERN is just a simplified test to confirm 8.0.1
>> working before I update to the real regexp, and my understanding is it
>> should map anything that ends in .map? But every map argument I throw
>> in (including verified working arguments for 7.6.2) result in a
>> failure to validate. Are there other crucial configurations missing
>> that are necessary to pass validation?
>> Thanks,
>> Matt
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://list/
>> s.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-users&data=05%7C02%7Cmatt
>> .lernout%40stantec.com%7C34322cf56ae745f61ae908dc27b617c5%7C413c6f2c21
>> 9a469297d3f2b4d80281e7%7C0%7C0%7C638428910243105153%7CUnknown%7CTWFpbG
>> Zsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%
>> 3D%7C0%7C%7C%7C&sdata=c%2BjBl2NTy%2BIZxCYZmp0CLwa2ujlD%2BC%2BfzzIQgXKw
>> lyI%3D&reserved=0
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der http://www.foss-academy.com/
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> http://www.wheregroup.com/
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>  Caution: This email originated from outside of Stantec. Please take
> extra precaution.
>  Attention: Ce courriel provient de l'extérieur de Stantec. Veuillez
> prendre des précautions supplémentaires.
>  Atención: Este correo electrónico proviene de fuera de Stantec. Por
> favor, tome precauciones adicionales.
More information about the MapServer-users mailing list
