[MapServer-users] option to use sld in mapfile to configure layer styling
Seth G sethg at geographika.co.uk
Thu Jan 18 07:35:32 PST 2024
Hi Paul,
I think all the code functions are in place to do the bulk of this work, and this would be a nice addition to MapServer. Sharing SLD between applications is a huge benefit. If it is possible to apply SLD from a URL it should also be possible to apply SLD from disk.
I wouldn't be a huge fan of embedding SLD directly in a Mapfile (although the CONNECTION parameter can accept large chunks of OGRVRTDataSource XML as long as quotes are escaped).
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Tue, Jan 16, 2024, at 6:11 PM, Paul via MapServer-users wrote:
> mapserver has capability to use SLD to style a layer, by appending sld to request
> unfortunately there is currently no option to use sld as part of mapfile to style a layer
> what do you think to add this as a new feature to next version?
> syntax could be something like this:
> LAYER
>   STYLEITEM "sld://mysldfile.xml" # relative path
>   CLASS
>   END
> END
> Alternative to introduce it also as embedded SLD, but the mix of ms syntax and xml is not very nice.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240118/82fed8a7/attachment.htm>
More information about the MapServer-users mailing list
