[MapServer-users] Error in msplugin_oracle.dll / maporaclespatial.c
Kulawik, Robert
KulawikR at eba.bund.de
Tue Jul 23 01:48:21 PDT 2024
Hello Mapserver community,
I've been getting an error since Mapserserver 8.X with Oracle Spatial 19c request using the function "osAggrGetExtent" when I reference a database table:
[Mon Jul 22 18:42:36 2024].226000 osAggrGetExtent was called: SELECT SDO_AGGR_MBR(GEOMETRIE) AS GEOM from (SELECTGEOMETRIE FROM (select OID, KLASSE, GEOMETRIE from MYTABLE)).
There is no space inserted between SELECT and GEOMETRIE (see SELECTGEOMETRIE FROM...)
this produces an error:
[Mon Jul 22 18:42:36 2024].227000 Error: ORA-00907: Rechte Klammer fehlt (Right bracket missing)
. Query statement: SELECT SDO_AGGR_MBR(GEOMETRIE) AS GEOM from (SELECTGEOMETRIE FROM (select OID, KLASSE, GEOMETRIE from MYTABLE)) .Check your data statement.in msOracleSpatialLayerGetExtent()
[Mon Jul 22 18:42:36 2024].227000 msOracleSpatialLayerGetExtent(): OracleSpatial error. Check your data statement and server logs
The result is that the layer is not loaded.
My request in the mapfile ist:
DATA 'GEOMETRIE from (select OID, KLASSE, GEOMETRIE from MYTABLE) USING UNIQUE OID SRID 25832'
the connection uses the oci plugin "msplugin_oracle.dll"
I use the mapserver 8.2.0 with GDAL 3.9.1 from gisinternals.com for now under Win Server 2019
https://gisinternals.com/query.html?content=filelist&file=release-1930-x64-gdal-3-9-1-mapserver-8-2-0.zip
does anyone have a solution for this problem?
thanks in advance
Best regards / viele Grüße
Robert Kulawik
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240723/fa9d55ce/attachment.htm>
More information about the MapServer-users
