[MapServer-users] Error in msplugin_oracle.dll / maporaclespatial.c
Kulawik, Robert KulawikR at eba.bund.de
Wed Jul 24 01:29:49 PDT 2024
as answer to Seth G and Sven S fron other reply:
the suggestion to use that Statment : DATA "GEOM FROM (SELECT * FROM TEST_TABLE) AS tbl USING UNIQUE ObjectId USING SRID=25832"
is not working,
"(SELECT * FROM TEST_TABLE) AS tbl" and/or "SRID=25832" both produce this error:
Error parsing OracleSpatial DATA variable. Must be: 'geometry_column FROM table_name [USING UNIQUE <column> SRID srid# FUNCTION]' or 'geometry_column FROM (SELECT stmt) [USING UNIQUE <column> SRID srid# FUNCTION]'. If want to set the FUNCTION statement you can use: FILTER, RELATE, GEOMRELATE or NONE.
the space is simply missing in Mapserver request SELECTGEOMETRIE
"osAggrGetExtent was called: SELECT SDO_AGGR_MBR(GEOMETRIE) AS GEOM from (SELECTGEOMETRIE FROM (select OID, KLASSE, GEOMETRIE from MYTABLE))"
Statement
Does somebody has any idea?
Best regards / viele Grüße
Robert Kulawik
-----Ursprüngliche Nachricht-----
Von: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Im Auftrag von Kulawik, Robert via MapServer-users
Gesendet: Dienstag, 23. Juli 2024 10:48
An: mapserver-users at lists.osgeo.org
Betreff: [MapServer-users] Error in msplugin_oracle.dll / maporaclespatial.c
Hello Mapserver community,
I've been getting an error since Mapserserver 8.X with Oracle Spatial 19c request using the function "osAggrGetExtent" when I reference a database table:
[Mon Jul 22 18:42:36 2024].226000 osAggrGetExtent was called: SELECT SDO_AGGR_MBR(GEOMETRIE) AS GEOM from (SELECTGEOMETRIE FROM (select OID, KLASSE, GEOMETRIE from MYTABLE)).
There is no space inserted between SELECT and GEOMETRIE (see SELECTGEOMETRIE FROM.)
this produces an error:
[Mon Jul 22 18:42:36 2024].227000 Error: ORA-00907: Rechte Klammer fehlt (Right bracket missing)
. Query statement: SELECT SDO_AGGR_MBR(GEOMETRIE) AS GEOM from (SELECTGEOMETRIE FROM (select OID, KLASSE, GEOMETRIE from MYTABLE)) .Check your data statement.in msOracleSpatialLayerGetExtent()
[Mon Jul 22 18:42:36 2024].227000 msOracleSpatialLayerGetExtent(): OracleSpatial error. Check your data statement and server logs
The result is that the layer is not loaded.
My request in the mapfile ist:
DATA 'GEOMETRIE from (select OID, KLASSE, GEOMETRIE from MYTABLE) USING UNIQUE OID SRID 25832'
the connection uses the oci plugin "msplugin_oracle.dll"
I use the mapserver 8.2.0 with GDAL 3.9.1 from gisinternals.com for now under Win Server 2019
https://gisinternals.com/query.html?content=filelist&file=release-1930-x64-gdal-3-9-1-mapserver-8-2-0.zip
does anyone have a solution for this problem?
thanks in advance
Robert Kulawik
More information about the MapServer-users mailing list
