[MapServer-users] Error in msplugin_oracle.dll / maporaclespatial.c
Kulawik, Robert KulawikR at eba.bund.de
Fri Jul 26 09:54:51 PDT 2024
Unfortunately we don't have any postges instances, but it's probably an error in the Oracle integration.
I checked my other mapfiles and logs, the error occurs in some mapfiles, but not in others. Strange because they are all structured in the same way. No magic characters or wrong formats.
The error occurs when requesting the service capabilities. I don't know whether the mapserver uses the mbr but the layer apparently loads in the same way as without errors. It is difficult to compare that.
If the cause isn't easy to figure out, I can live with it
Thanks for your help Richard
Best regards / viele Grüße
Robert Kulawik
-----Ursprüngliche Nachricht-----
Von: Richard Duivenvoorde <rdmailings at duif.net>
Gesendet: Donnerstag, 25. Juli 2024 11:52
An: Kulawik, Robert <KulawikR at eba.bund.de>; mapserver-users at lists.osgeo.org
Betreff: Re: AW: [MapServer-users] Error in msplugin_oracle.dll / maporaclespatial.c
Maybe msStringConcatenate has issues?
Could you create a reproducable issue from it?
( preferably without needing an Oracle db :-) )
Also: is this only one data statement? Or are the more (in your mapfiles)?
Is this happening only in Oracle data?
Could it be some 'magic chars' around it? Like utf-special quotes (those tricky Windows double quotes, or tabs or ...)
Sorry for not able to be more helpful
Regards,
On 7/25/24 09:23, Kulawik, Robert wrote:
> Hi Richard,
> thank you for your answer.
> I'm not alone with this problem, two other users also reported it
> You are right, the code in maporaclespatial.c looks good for me too.
> And yes, when I insert an "x" in the data statement like DATA
> 'xGEOMETRIE....' then I get SELECTxGEOMETRIE Putting one or more spaces instead of "x", the the spaces are removed and I get SELECTGEOMETRIE again.
> Maybe a space ist missing when passing parameters between maporaclespatial.c and msOracleSpatialLayerGetExtent() or another funktion?
> Robert Kulawik
> Gesendet: Mittwoch, 24. Juli 2024 16:42
> Betreff: Re: [MapServer-users] Error in msplugin_oracle.dll /
> maporaclespatial.c
> Searching in the mapserver code, based on your errors you will end up around here:
> https://github.com/MapServer/MapServer/blob/rel-8-2-1/src/maporaclespa
> tial.c
> it does not look like there something can insert 'SELECT' into the query.
> Are you 100% sure that the SELECTGEOMETRIE does not come from (one of) your mapfiles?
> Another thing I would try: can you insert some spaces into your DATA string:
> DATA '  GEOMETRIE from (select OID, KLASSE, GEOMETRIE from MYTABLE) USING UNIQUE OID SRID 25832'
> of for testing:
> DATA 'xGEOMETRIE from (select OID, KLASSE, GEOMETRIE from MYTABLE) USING UNIQUE OID SRID 25832'
> and see if you'll end up with SELECTxGEOMETRIE then?
> Else, try to run a container maybe with the same map file (but other Mapserver version)?
> Regards,
> On 7/24/24 10:29, Kulawik, Robert via MapServer-users wrote:
>> Hi,
>> as answer to Seth G and Sven S fron other reply:
>> the suggestion to use that Statment : DATA "GEOM FROM (SELECT * FROM TEST_TABLE) AS tbl USING UNIQUE ObjectId USING SRID=25832"
>> is not working,
>> "(SELECT * FROM TEST_TABLE) AS tbl" and/or "SRID=25832" both produce this error:
>> Error parsing OracleSpatial DATA variable. Must be: 'geometry_column FROM table_name [USING UNIQUE <column> SRID srid# FUNCTION]' or 'geometry_column FROM (SELECT stmt) [USING UNIQUE <column> SRID srid# FUNCTION]'. If want to set the FUNCTION statement you can use: FILTER, RELATE, GEOMRELATE or NONE.
>> the space is simply missing in Mapserver request SELECTGEOMETRIE
>> "osAggrGetExtent was called: SELECT SDO_AGGR_MBR(GEOMETRIE) AS GEOM from (SELECTGEOMETRIE FROM (select OID, KLASSE, GEOMETRIE from MYTABLE))"
>> Statement
>> Does somebody has any idea?
>> Robert Kulawik
>> Von: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Im
>> Auftrag von Kulawik, Robert via MapServer-users
>> Gesendet: Dienstag, 23. Juli 2024 10:48
>> An: mapserver-users at lists.osgeo.org
>> Betreff: [MapServer-users] Error in msplugin_oracle.dll /
>> maporaclespatial.c
>> Hello Mapserver community,
>> I've been getting an error since Mapserserver 8.X with Oracle Spatial 19c request using the function "osAggrGetExtent" when I reference a database table:
>> [Mon Jul 22 18:42:36 2024].226000 osAggrGetExtent was called: SELECT SDO_AGGR_MBR(GEOMETRIE) AS GEOM from (SELECTGEOMETRIE FROM (select OID, KLASSE, GEOMETRIE from MYTABLE)).
>> There is no space inserted between SELECT and GEOMETRIE (see
>> SELECTGEOMETRIE FROM.)
>> this produces an error:
>> [Mon Jul 22 18:42:36 2024].227000 Error: ORA-00907: Rechte Klammer
>> fehlt (Right bracket missing) . Query statement: SELECT
>> OID, KLASSE, GEOMETRIE from MYTABLE)) .Check your data statement.in
>> msOracleSpatialLayerGetExtent() [Mon Jul 22 18:42:36 2024].227000
>> msOracleSpatialLayerGetExtent(): OracleSpatial error. Check your data
>> statement and server logs
>> The result is that the layer is not loaded.
>> My request in the mapfile ist:
>> DATA 'GEOMETRIE from (select OID, KLASSE, GEOMETRIE from MYTABLE) USING UNIQUE OID SRID 25832'
>> the connection uses the oci plugin "msplugin_oracle.dll"
>> I use the mapserver 8.2.0 with GDAL 3.9.1 from gisinternals.com for
>> now under Win Server 2019
>> https://gisinternals.com/query.html?content=filelist&file=release-193
>> 0-x64-gdal-3-9-1-mapserver-8-2-0.zip
>> does anyone have a solution for this problem?
>> thanks in advance
>> Robert Kulawik
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
