[MapServer-users] Cluster style crashes MapServer 8
    Seth G
    sethg at geographika.co.uk
    Tue Jun 11 00:51:06 PDT 2024
A couple of things to try to narrow down the issue:
1. If you are able to export the PostGIS layer to a shapefile, then you can change the DATA of the layer and see if there is still a crash.
2. Is there an EXTENT set on the layer? I ran into an issue using MS SQL [1] and clustering. Try adding one manually.
Seth
[1] https://github.com/MapServer/MapServer/pull/6278
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Tue, Jun 11, 2024, at 9:31 AM, Jaques Tati via MapServer-users wrote:
> Hi There,
> in our application we're upgrading our v7.6 MapServer to v8.01.
> Everything seems to work good so far but we have one layer that uses
> Clustering of points
> and whenever this layer should be displayed MapServer 8 crashes
> reproducably.
> This layer works flawless in v7.6 and clustering is setup exactly from
> the book.
> When i comment clustering out, the layer is displayed, so all other
> style features do work.
> Datasource is a PostGIS layer, webserver is Apache 2.4.59.
> Looking at the debug output, the data comes back as expected from the
> database,
> even clustering is logged and no error in the MapServer-Logfile.
> The crash is reported in Windows Application-Eventlog with only cryptic
> reasons that do
> not really result in any valid answers when googling.
> ..there is a word "StackHash" included that might point to DEP
> (DataExecutionPrevention)
> of Windows, - but since all other layers do work with the MapServer-Exe
> it would be hard
> to understand why windows does prevent the output of clustered layers.
> We're using Windows Server 2022 21H2 Datacenter Edition, 8 CPU 32GB RAM.
> Anyone heard of this crude behaviour, I'm running out of ideas?
> Thanks in advance for any hint
> SH
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
