[MapServer-users] If clustering is used, the capabilities are not completely created
Seth G sethg at geographika.co.uk
Mon Jun 3 12:23:27 PDT 2024
Hi Luuk,
What does your GetCapabilities request look like (version etc.)?
What error do you get?
Does the LAYER have an EXTENT set on it? Maybe there is an issue with trying to calculate this dynamically - if there isn't an extent you could try adding one.
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Mon, Jun 3, 2024, at 4:52 PM, Schaminée, drs. L.C.W. (Luuk) via MapServer-users wrote:
> Hi List,
> Does anybody recognize this problem?
> We use clustering in a layer in our WMS. This works fine. But if we ask for the capabilities we get an error and only part of the capabilities..
> We uise the following lines in our mapfile in the LAYER section:
>     CLUSTER
>       MAXDISTANCE 15
>       BUFFER 10
>       REGION "ellipse" # This line is responsible for not being able to get the capabilities
>     END
> If we comment out the line REGION “ellipse” we can get the complete capabilities.
> Hopefully somebody knows this problem and also knows a/the solution.
> Thanks for any help.
> Luuk
> Dit bericht kan informatie bevatten die niet voor u is bestemd. Indien u
> niet de geadresseerde bent of dit bericht abusievelijk aan u is gezonden,
> wordt u verzocht dat aan de afzender te melden en het bericht te
> verwijderen.
> De Staat aanvaardt geen aansprakelijkheid voor schade, van welke aard
> ook, die verband houdt met risico's verbonden aan het elektronisch
> verzenden van berichten.
> This message may contain information that is not intended for you. If you
> are not the addressee or if this message was sent to you by mistake, you
> are requested to inform the sender and delete the message.
> The State accepts no liability for damage of any kind resulting from the
> risks inherent in the electronic transmission of messages.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240603/1fc9b54c/attachment.htm>
More information about the MapServer-users mailing list
