[MapServer-users] setting COLOR of SVG symbol ?
Seth G sethg at geographika.co.uk
Thu Mar 28 00:05:48 PDT 2024
Unfortunately, I don't think this is currently possible, based on a previous reply from Steve Lime [1]:
> I don't believe you can muck with the SVG color since SVG can carry multiple elements and colors. That complexity doesn't map very well to a single color value in a styleObj. It's probably best to consider SVG as immutable, same as an image symbol. You can use truetype fonts (or vector symbols) if you want something scaleable where you can alter color.
I guess if it works in QGIS then it should be possible to implement this in the MapServer codebase too.
Seth
[1] https://lists.osgeo.org/pipermail/mapserver-users/2019-June/081218.html
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Mar 27, 2024, at 10:45 PM, karsten via MapServer-users wrote:
> Hi All,
> for the first time trying to use svg symbols for a layer. The svgs I am using can be styled in QGIS (have edited to allow).
> What is the status in MapServer should setting  the color via a style work ?
> I had no luck setting the COLOR on the symbol so far
> Here is my style
>      STYLE
>        SYMBOL "electric_point"
>        SIZE 20
>        COLOR 255 0 0
>      END # STYLE
> symbol
> SYMBOL
>     NAME 'electric_point'
>     TYPE svg
>     image 'symbols/annotation/electric.svg'
> END
> So far this renders black symbols , any ideas how to fix this ?
> Cheers
> Karsten
> Karsten Vennemann
> www.terragis.net
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240328/a0441c5d/attachment.htm>
More information about the MapServer-users mailing list
