[MapServer-users] setting COLOR of SVG symbol ?
karsten karsten at terragis.net
Thu Mar 28 13:59:45 PDT 2024
Thanks,
looks like it.
In QGIS setting color and opacity plus stroke does only work if the *.svg is
edited to allow by setting variables such as these below:
style="fill:param(fill) #000000;fill-opacity:1;stroke:param(outline)
#000000;stroke-width:param(stroke-width) 1;fill-opacity:param(fill-opacity)
1;stroke-opacity:param(outline-opacity) "
I guess a simple approach could be to allow setting colors for svgs in
MapServer if the svg has the style color set to
fill="currentColor"
in order to be styled
For now seems that MapServer vector symbols seem to be the way to go
Cheers
Karsten
  _____
Sent: Thursday, March 28, 2024 00:06
To: karsten; MapServer Users
Subject: Re: [MapServer-users] setting COLOR of SVG symbol ?
Unfortunately, I don't think this is currently possible, based on a previous
reply from Steve Lime [1]:
> I don't believe you can muck with the SVG color since SVG can carry
multiple elements and colors. That complexity doesn't map very well to a
single color value in a styleObj. It's probably best to consider SVG as
immutable, same as an image symbol. You can use truetype fonts (or vector
symbols) if you want something scaleable where you can alter color.
I guess if it works in QGIS then it should be possible to implement this in
the MapServer codebase too.
Seth
[1] https://lists.osgeo.org/pipermail/mapserver-users/2019-June/081218.html
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Mar 27, 2024, at 10:45 PM, karsten via MapServer-users wrote:
Hi All,
for the first time trying to use svg symbols for a layer. The svgs I am
using can be styled in QGIS (have edited to allow).
What is the status in MapServer should setting  the color via a style work ?
I had no luck setting the COLOR on the symbol so far
Here is my style
     STYLE
       SYMBOL "electric_point"
       SIZE 20
       COLOR 255 0 0
     END # STYLE
symbol
SYMBOL
    NAME 'electric_point'
    TYPE svg
    image 'symbols/annotation/electric.svg'
END
So far this renders black symbols , any ideas how to fix this ?
Cheers
Karsten
Karsten Vennemann
 <http://www.terragis.net> www.terragis.net
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240328/908f788c/attachment.htm>
More information about the MapServer-users mailing list
