No subject
Mon Oct 7 05:54:23 PDT 2024
Number: Datum:                       Area:          Ellipsoid:
1001       Pulkovo 1942         Germany      Krassovsky
You will have to look up the EPSG code for your particular map projection
that uses this datum.
Brent Fraser
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Wednesday, January 26, 2005 2:13 AM
Subject: [UMN_MAPSERVER-USERS] relation between .tab and .map
Does anyone know any web page were indicates the posible values that the
parameters of the coordsys earth projection can have in a .tab file?
parameters of the  projection  of a .map file can have?
All I want is to put the parameters of the projection from my .tab file to
my .map file, but it doesn't work. For example the "datum" in the corrdsys
earth projection is 1001 but in the map file I do not know what it
corresponds to (NAD27,WG83,...)
Thank you
Jose Luis
More information about the MapServer-users mailing list
