No subject
Mon Oct 7 05:54:23 PDT 2024
tags around your select element.  You will need to remove those. (Perhaps
that's why moving the select element makes it work now?)
Adding an onchange event should work fine.  As for re-selecting the chosen
quick zoom after the page has refreshed, there are many ways to do it, I
just build the option list in php.  Something like this:
$aszOpList = array('7120999,827999,7599999,1119999'=>'Lake Ontario',
'7200000,833270,7291840,894520'=>'Niagara (ON)');
$szOpList = '';
foreach ( $ aszOpList as $key=>$szOp )
    // determine selected
    $szTmpSelect = ( isset(  $HTTP_FORM_VARS['ViewRegion'] ) &&
                     $HTTP_FORM_VARS [' ViewRegion '] == $key ) ?
                        ' selected' : '';
    // add next option
    $szOpList.= '<option value="'.$key.'"'.$szTmpSelect.
        '>'.$szOp.'</option>';
That will build your list (be sure to add all the items) each time and
select an item if you have zoomed to that extent.
I do foresee another problem that you will have, that is each time you
refresh the page, it will attempt to do a quick zoom because there will
always be a value selected.
Add a hidden textbox to signal a quick zoom request:
<input type="hidden" name="doQuickZoom" value="">
In your onChange function set the value:
document.forms[0].doQuickZoom.value = 1;
document.forms[0].submit();
Then back in PHP only execute the quick zoom when doQuickZoom is set to 1:
If ( isset( $HTTP_FORM_VARS['doQuickZoom']) &&
$HTTP_FORM_VARS['doQuickZoom'] == 1 )
HTH
Bill
______________________________
William A. Bronsema, C.E.T.
Applications and Software Development,
DM Solutions Group Inc.
> -----Original Message-----
> From: Kevin Grootendorst [mailto:kgrootendorst at BAIRD.COM]
> Sent: January 26, 2005 11:36 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU; William Bronsema
> Subject: Re: Zoom to custom extent - PHP
> Hi Bill,
> The quick zoom seems to be working now, but the ROSA tools do not respond,
> nor does the legend/layer list.  I moved the code in the 'contents.php'
> to 'higher up' in the file (no longer at bottom).  Once I select the
> region
> from the dropdown list, and click refresh, the map zooms to where it
> should.  However, the list defaults back to the first option.  It would
> also be nice to implement an 'onchange' event, so that I don't have to use
> the refresh button to zoom to the region (I'm wondering when things do
> work, if adding a layer and refreshing will automatically zoom to the
> first
> extent in the 'View Region' drop down list).
> Kevin
> On Wed, 26 Jan 2005 07:29:44 -0500, William Bronsema
> <wbronsema at DMSOLUTIONS.CA> wrote:
> >Kevin,
> >The javascript error is not preventing your map from zooming, something
> else
> >is.  There is likely some other PHP code that is resetting the extents
> after
> >your quick zoom code.
> >The javascript error you are getting occurs because the function you
> listed
> >cannot find the hidden textbox called "QueryString".  Did you happen to
> >remove it or move it outside of the form called "main"?
> >Send me your app off-list and I will take a quick look.
> >Bill
> >________________________________________________
> >> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On
> >> Behalf Of Kevin Grootendorst
> >> Sent: January 25, 2005 2:52 PM
> >> Subject: Re: [UMN_MAPSERVER-USERS] Zoom to custom extent - PHP
> >> I've implemented the code, and now I'm even convinced it should work.
> But
> >> no such luck yet.  The debugging works just as it should, but when it
> >> should 'quick zoom now', the map still draws to the project's max
> extents.
> >> However, I do receive a windows js error box indicating a problem in
> the
> >> app.phmtl file:
> >> 'document.main.QueryString.value' is null or not an object.
> >> Here is my javascript from the .phtml file:
> >> <script language="javascript">
> >> window.resizeTo(1024,768);
> >>  * This function runs after the form is done loading
> >> function doneLoading()
> >>     // show the query results page if query
> >>     if ( document.main.QueryString.value != "" )
> >>         // complete the string
> >>         document.main.QueryString.value = "?PrevStateKey=" +
> >> document.main.PrevStateKey.value + "&INPUT_COORD=" +
> >> document.main.INPUT_COORD.value;
> >>         // calculate the center
> >>         if (document.all)
> >>             var xMax = screen.width, yMax = screen.height;
> >>         else if (document.layers)
> >>             var xMax = window.outerWidth, yMax = window.outerHeight;
> >>         else
> >>             //var xMax = 640, yMax=480;
> >>   var xMax = 800, yMax=600;
> >>         var xOffset = (xMax - 510)/2, yOffset = (yMax - 390)/2;
> >> //QUERY RESULTS WINDOW
> >>         // load the processing page
> >>         mapquery = window.open('query.phtml' +
> document.main.QueryString.value,'mapquery','scrollbars=yes,resizable=yes,w
> >> id
> th=800,height=600,screenX='+xOffset+',screenY='+yOffset+',top='+yOffset+',
> >> le
> >> ft='+xOffset+'');
> >>         // give it focus
> >>         mapquery.focus();
> >>     // exit
> >>     return;
> >> </script>
> >> Could this somehow be preventing my php code from working?
More information about the MapServer-users mailing list
