No subject
Mon Oct 7 05:54:23 PDT 2024
  --with-jpeg=DIR       Include JPEG support (DIR is LibJPEG's install dir).
  --with-gd=[static,]DIR Specify which version of GD to use (DIR is GD's
                          install dir).
I believe in your case you would want to use:
/home/water/a/watergen for both.
Ed Cooley
Strategy Systems, Inc.
> -----Original Message-----
> From: ABE Water Research Account [mailto:watergen at ECN.PURDUE.EDU]
> Sent: Saturday, August 06, 2005 12:40 PM
> Subject: MapServer4.6 install:can't find gd.h and jpeg
> Hi, all,
>    I 've spent three days worth of time to get all the latest version of
> tools for MS4.6 and compiled/install them with no error and updated
> LD_LIB... env, then MapServer configure kept saying it can't find my
> gd.h and libgd... and neither can it find jpeglib.h and libjpeg.*.
>    Due to system restriction, we like to install on local user account,
> you
> know, not the /usr/local defaul locations, and I have the bin/ lib/
> include/ share/ etc all set up nicely and all the files are there...
> so I configure it like:
> ./configure   --prefix=$HOME \
>                --enable-debug \
>                --with-sde=/home/water/a/watergen/lib/sde/sdeexe83 \
>                --with-sde-version=83 \
>                --with-zlib==/home/water/a/watergen/lib \
>                --with-freetype=/home/water/a/watergen/bin/freetype-config
>                --with-jpeg=/home/water/a/watergen/lib \
>                --with-png=/home/water/a/watergen/lib \
>                --with-ogr=/home/water/a/watergen/bin/gdal-config \
>                --with-gdal=/home/water/a/watergen/bin/gdal-config \
>                --with-pdf=/home/water/a/watergen/bin/pdflib-config \
>                --with-tiff=/home/water/a/watergen/lib \
>                --with-curl-config=/home/water/a/watergen/bin/curl-config \
>                --with-proj=/home/water/a/watergen/lib \
>                --with-gd=/home/water/a/watergen/bin/gdlib-config \
>                --with-threads
> and I get back:
> configure: checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
>          using libz from system libs.
> configure: checking where PNG is installed...
>          using libpng from -L/home/water/a/watergen/lib -lpng
> configure: checking whether we should include JPEG support...
>          using libjpeg from system -L/home/water/a/watergen/lib -ljpeg
> configure: checking where libXpm is installed...
> checking for XpmFreeXpmImage in -lXpm... yes
>          using libXpm from system libs.
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... yes
> checking for libiconv_open in -liconv... yes
>          using libiconv from system libs.
>          libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.16 or higher...
> checking for gdFontCacheSetup in -lgd... no
> configure: checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /home/danpatch/a/watergen/bin/gdlib-config.  Make sure GD 2.0.16 or higher
> is compiled before calling configure. You may also get this error if you
> didn't specify the appropriate location for one of GD's dependencies
> (freetype, libpng, libjpeg or libiconv).
> our system specs:
> Machine hardware:   sun4u
> OS version:         5.8
> Processor type:     sparc
> Hardware:           SUNW,Ultra-4
>    Then when our collected hair on our heads all pulled out, I just
> configure it without any --with, it passed. So I guess this new version or
> previous version(s) just need to get things from default places.
>    I still hold out hope that we can still put things locally, please let
> us know any suggestions,
>    Best,
>    Baldy
More information about the MapServer-users mailing list
