[MapServer-users] How to handle multiple styles in MapCache?
Alessandro Parma
alessandro.parma at geosolutionsgroup.com
Fri Sep 13 08:47:58 PDT 2024
Dear ML,
I am using MapCache version 1.8 and having issues with the caching
configuration of one of the layers:
The layer in question can be requested with multiple different styles but
it looks like the STYLE parameter in
the GetMap requests is ignored and I get the same cached tiles no matter
what the style value of the request is.
This is a snippet of the configuration:
<source name="mtg_fd:ir105_hrfi" type="wms">
<getmap>
<params>
<TRANSPARENT>true</TRANSPARENT>
<TILED>false</TILED>
<LAYERS>mtg_fd:ir105_hrfi</LAYERS>
</params>
</getmap>
<http>
<url>http://wms-geoserver-slave-svc:8080/geoserver/wms?</url>
</http>
<timeout>10</timeout>
<connection_timeout>3</connection_timeout>
</source>
<tileset name="mtg_fd:ir105_hrfi">
<source>mtg_fd:ir105_hrfi</source>
<cache>multitier-cache</cache>
<grid use_wms_intermediate_resolutions="true">EPSG4326_512</grid>
<grid use_wms_intermediate_resolutions="true">EPSG3995_512</grid>
<grid use_wms_intermediate_resolutions="true">EPSG3857_512</grid>
<grid use_wms_intermediate_resolutions="true">EPSG3976_512</grid>
<dimensions>
<dimension type="regex" name="TIME" default="now">
<regex>^.*$</regex>
</dimension>
</dimensions>
<format>MIXED</format>
<metatile>1 1</metatile>
<metabuffer>10</metabuffer>
<expires>604800</expires>
</tileset>
Do you have any suggestions?
Regards, Alessandro Parma == GeoServer Professional Services from the
experts! Visit http://goo.gl/it488V for more information. == Alessandro
Parma Technical Lead / Senior DevOps Engineer GeoSolutions S.A.S. Via di
Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 340 4752467 fax: +39
0584 1660272 https://www.geosolutionsgroup.com
https://twitter.com/geosolutions_it
------------------------------------------------------- Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20240913/5d9f81c8/attachment.htm>
More information about the MapServer-users
