[MapServer-users] How to handle multiple styles in MapCache?
Just van den Broecke
justb4 at gmail.com
Fri Sep 13 14:11:09 PDT 2024
Hi Alessandro,
I try to understand your issue. Beware, I am not a MapCache expert.
You mention a GetMap request and STYLE (not STYLES?) parameter. MapCache
supports tiling, like WMTS GetTile, not WMS GetMap.
But looking at the MapCache docs (1.8 is quite old) [1]. The <getmap>
element within the <source> element may contain WMS parameters,
including STYLES. These will be sent to the WMS (GeoServer) backend (as
GetMap). But I see no way how one could have varying Styes for a
tilecache, other than a separate cache per STYLES value.
[1] https://mapserver.org/fr/mapcache/config.html
Hope this helps!
Best,
Just
On 13/09/2024 17:47, Alessandro Parma via MapServer-users wrote:
> Dear ML,
> I am using MapCache version 1.8 and having issues with the caching
> configuration of one of the layers:
> The layer in question can be requested with multiple different styles
> but it looks like the STYLE parameter in
> the GetMap requests is ignored and I get the same cached tiles no matter
> what the style value of the request is.
> This is a snippet of the configuration:
> <source name="mtg_fd:ir105_hrfi" type="wms">
> <getmap>
> <params>
> <TRANSPARENT>true</TRANSPARENT>
> <TILED>false</TILED>
> <LAYERS>mtg_fd:ir105_hrfi</LAYERS>
> </params>
> </getmap>
> <http>
> <url>http://wms-geoserver-slave-svc:8080/geoserver/wms
> <http://wms-geoserver-slave-svc:8080/geoserver/wms>?</url>
> </http>
> <timeout>10</timeout>
> <connection_timeout>3</connection_timeout>
> </source>
> <tileset name="mtg_fd:ir105_hrfi">
> <source>mtg_fd:ir105_hrfi</source>
> <cache>multitier-cache</cache>
> <grid use_wms_intermediate_resolutions="true">EPSG4326_512</grid>
> <grid use_wms_intermediate_resolutions="true">EPSG3995_512</grid>
> <grid use_wms_intermediate_resolutions="true">EPSG3857_512</grid>
> <grid use_wms_intermediate_resolutions="true">EPSG3976_512</grid>
> <dimensions>
> <dimension type="regex" name="TIME" default="now">
> <regex>^.*$</regex>
> </dimension>
> </dimensions>
> <format>MIXED</format>
> <metatile>1 1</metatile>
> <metabuffer>10</metabuffer>
> <expires>604800</expires>
> </tileset>
> Do you have any suggestions?
> Regards, Alessandro Parma == GeoServer Professional Services from the
> experts! Visit http://goo.gl/it488V <http://goo.gl/it488V> for more
> information. == Alessandro Parma Technical Lead / Senior DevOps Engineer
> GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy
> phone: +39 340 4752467 fax: +39 0584 1660272
> https://www.geosolutionsgroup.com <https://www.geosolutionsgroup.com>
> https://twitter.com/geosolutions_it
> <https://twitter.com/geosolutions_it>
> ------------------------------------------------------- Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati “GDPR”), si precisa che
> ogni circostanza inerente alla presente email (il suo contenuto, gli
> eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i
> solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è
> giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è
> illecita. Le sarei comunque grato se potesse darmene notizia. This email
> is intended only for the person or entity to which it is addressed and
> may contain information that is privileged, confidential or otherwise
> protected from disclosure. We remind that - as provided by European
> Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake,
> please notify us immediately by telephone or e-mail.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
