[MapServer-users] How to handle multiple styles in MapCache?
Just van den Broecke
justb4 at gmail.com
Tue Sep 17 05:21:32 PDT 2024
Almost there, two things:
- the names of your (cached) Layers are names of the tilesets like:
'layerA_style1' etc I think)
- if you need to use WMS (tiling services like WMTS is preferred) use
these names in LAYER=, do not use STYLES= as thes are implicit for the
Layers.
Best is: do a REQUEST=GetCapabilities on the WMS (and WMTS) to see what
the possible Layers and other params like projections/grids are.
Best,
Just
On 17/09/2024 12:40, Alessandro Parma wrote:
> Thanks for your reply,
> That's right, the parameter is called STYLES not STYLE it was a typo in
> my email.
> It is fine for me to create multiple caches, one per each style, that is
> expected. I've tried to follow your suggestion
> and create separate sources and tilesets for the same layer as follows:
> <source name="*layerA_style1*" type="wms">
> <getmap>
> <params>
> <TRANSPARENT>true</TRANSPARENT>
> <TILED>false</TILED>
> *<LAYERS>layerA</LAYERS>
> <STYLES>style1</STYLES>*
> </params>
> </getmap>
> <http>
> <url>http://wms-geoserver-slave-svc:8080/geoserver/wms <http://
> wms-geoserver-slave-svc:8080/geoserver/wms>?</url>
> </http>
> <timeout>10</timeout>
> <connection_timeout>3</connection_timeout>
> </source>
> <source name="*layerA_style2*" type="wms">
> <getmap>
> <params>
> * <LAYERS>layerA</LAYERS>
> <STYLES>style2</STYLES>*
> </params>
> </getmap>
> <http>
> </http>
> </source>
> * <tileset name="layerA_style1">
> <source>l**ayerA_style1**</source>*
> <cache>multitier-cache</cache>
> <grid use_wms_intermediate_resolutions="true">EPSG4326_512</grid>
> <grid use_wms_intermediate_resolutions="true">EPSG3995_512</grid>
> <grid use_wms_intermediate_resolutions="true">EPSG3857_512</grid>
> <grid use_wms_intermediate_resolutions="true">EPSG3976_512</grid>
> <dimensions>
> <dimension type="regex" name="TIME" default="now">
> <regex>^.*$</regex>
> </dimension>
> </dimensions>
> <format>MIXED</format>
> <metatile>1 1</metatile>
> <metabuffer>10</metabuffer>
> <expires>604800</expires>
> </tileset>
> * <tileset name="layerA_style2">
> <source>l**ayerA_style2**</source>*
> <dimensions>
> <regex>^.*$</regex>
> </dimension>
> </dimensions>
> </tileset>
> What I observe with this updated configuration by looking at mapcache
> logs and the source server logs is that it
> looks like the requests are always passed through to the origin WMS
> server and never cached in MapCache, as
> if mapcache was not matching my defined sources/tilesets. Here below two
> sample requests:
> https://mygeoserver.com/geoserver/wms?
> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/
> png&TRANSPARENT=true&LAYERS= <https://mygeoserver.com/geoserver/wms?
> png&TRANSPARENT=true&LAYERS=>*layerA*&STYLES=*style1*&WIDTH=512&HEIGHT=512&CRS=EPSG:4326&BBOX=0,-90,45,-45
> png&TRANSPARENT=true&LAYERS=>*layerA*&STYLES=*style2*&WIDTH=512&HEIGHT=512&CRS=EPSG:4326&BBOX=0,-90,45,-45
> Am I missing something in my configuration?
> Another question I had while checking the documentation <https://
> mapserver.org/mapcache/config.html#source> is if the parameters
> specified in the <params> are used to
> match the request to the given source (i.e. if the params in the
> incoming request match -> this is the right source configuration to use
> to serve the request) or
> if instead are used to override the parameters in the original http
> request with hardcoded values.
> Thank you,
> Alessandro
> On Fri, Sep 13, 2024 at 11:11 PM Just van den Broecke via MapServer-
> users <mapserver-users at lists.osgeo.org <mailto:mapserver-
> users at lists.osgeo.org>> wrote:
> Hi Alessandro,
> I try to understand your issue. Beware, I am not a MapCache expert.
> You mention a GetMap request and STYLE (not STYLES?) parameter.
> MapCache
> supports tiling, like WMTS GetTile, not WMS GetMap.
> But looking at the MapCache docs (1.8 is quite old) [1]. The <getmap>
> element within the <source> element may contain WMS parameters,
> including STYLES. These will be sent to the WMS (GeoServer) backend (as
> GetMap). But I see no way how one could have varying Styes for a
> tilecache, other than a separate cache per STYLES value.
> [1] https://mapserver.org/fr/mapcache/config.html <https://
> mapserver.org/fr/mapcache/config.html>
> Hope this helps!
> Best,
> Just
> On 13/09/2024 17:47, Alessandro Parma via MapServer-users wrote:
> > Dear ML,
> > I am using MapCache version 1.8 and having issues with the caching
> > configuration of one of the layers:
> > The layer in question can be requested with multiple different
> styles
> > but it looks like the STYLE parameter in
> > the GetMap requests is ignored and I get the same cached tiles no
> matter
> > what the style value of the request is.
> > This is a snippet of the configuration:
> > <source name="mtg_fd:ir105_hrfi" type="wms">
> > <getmap>
> > <params>
> > <LAYERS>mtg_fd:ir105_hrfi</LAYERS>
> > </params>
> > </getmap>
> > <http>
> <http://wms-geoserver-slave-svc:8080/geoserver/wms>
> > <http://wms-geoserver-slave-svc:8080/geoserver/wms <http://wms-
> geoserver-slave-svc:8080/geoserver/wms>>?</url>
> > </http>
> > </source>
> > <tileset name="mtg_fd:ir105_hrfi">
> > <source>mtg_fd:ir105_hrfi</source>
> > <grid
> > <grid
> > <grid
> grid>
> > <dimensions>
> > <regex>^.*$</regex>
> > </dimension>
> > </dimensions>
> > </tileset>
> > Do you have any suggestions?
> > Regards, Alessandro Parma == GeoServer Professional Services from
> the
> > experts! Visit http://goo.gl/it488V <http://goo.gl/it488V>
> <http://goo.gl/it488V <http://goo.gl/it488V>> for more
> > information. == Alessandro Parma Technical Lead / Senior DevOps
> Engineer
> > GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy
> > phone: +39 340 4752467 fax: +39 0584 1660272
> > https://www.geosolutionsgroup.com <https://
> www.geosolutionsgroup.com> <https://www.geosolutionsgroup.com
> <https://www.geosolutionsgroup.com>>
> > https://twitter.com/geosolutions_it <https://twitter.com/
> geosolutions_it>
> > <https://twitter.com/geosolutions_it <https://twitter.com/
> geosolutions_it>>
> > ------------------------------------------------------- Con
> riferimento
> > alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 -
> > Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che
> > ogni circostanza inerente alla presente email (il suo contenuto, gli
> > eventuali allegati, etc.) è un dato la cui conoscenza è riservata
> al/i
> > solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è
> > giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è
> > illecita. Le sarei comunque grato se potesse darmene notizia.
> This email
> > is intended only for the person or entity to which it is
> addressed and
> > may contain information that is privileged, confidential or
> otherwise
> > protected from disclosure. We remind that - as provided by European
> > Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> > e-mail or the information herein by anyone other than the intended
> > recipient is prohibited. If you have received this email by mistake,
> > please notify us immediately by telephone or e-mail.
> > MapServer-users mailing list
> > MapServer-users at lists.osgeo.org <mailto:MapServer-
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
> <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> MapServer-users at lists.osgeo.org <mailto:MapServer-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users <https://
> Regards, Alessandro Parma == GeoServer Professional Services from the
> experts! Visit http://goo.gl/it488V <http://goo.gl/it488V> for more
> information. == Alessandro Parma Technical Lead / Senior DevOps Engineer
> phone: +39 340 4752467 fax: +39 0584 1660272 https://
> www.geosolutionsgroup.com <https://www.geosolutionsgroup.com> https://
> twitter.com/geosolutions_it <https://twitter.com/geosolutions_it>
> ------------------------------------------------------- Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati “GDPR”), si precisa che
> eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i
> illecita. Le sarei comunque grato se potesse darmene notizia. This email
> is intended only for the person or entity to which it is addressed and
> may contain information that is privileged, confidential or otherwise
> Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-
More information about the MapServer-users
