[MapServer-users] WMS layer from multiple ogrtindex'd shapefiles - no such file or directory
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Wed Apr 30 00:57:40 PDT 2025
I believe that what you try to do is possible, but myself I would not waste my time for that because the property boundaries of the whole Finland are available as a single GeoPackage file from https://asiointi.maanmittauslaitos.fi/karttapaikka/tiedostopalvelu/kiinteistorekisterikartta_vektori?lang=fi.
Much more convenient than to struggle with thousands of shapefiles.
-Jukka Rahkonen-
________________________________________
Lähettäjä: MapServer-users käyttäjän Stefan Gofferje via MapServer-users puolesta
Lähetetty: Keskiviikko 30. huhtikuuta 2025 10.33
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [MapServer-users] WMS layer from multiple ogrtindex'd shapefiles - no such file or directory
I am a little bit at a loss here. I have tried multiple variations of
relative and absolute paths but can't get it to work.
I am trying to create a WMS service from thousands of shapefiles
containing property boundaries of Finland.
Sample files:
https://kartat.kapsi.fi/files/kiinteistorekisterikartta/avoin/karttalehdittain/tm35fin/shp/
I am running the latest camptocamp/mapserver docker container on X86_64
Ubuntu
MapServer version 8.4.0 PROJ version 9.5 GDAL version 3.10 OUTPUT=PNG
OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=FASTCGI
SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE INPUT=FLATGEOBUF
The directory structure inside the container is
/etc/mapserver.conf
/etc/mapserver/kiinteisto.map
/maps/kiinteisto
+-- rajat
| +-- 11,245 shp-files
+-- rajat.(shp|shx|prj|dbf)
kiinteisto.map
MAP
NAME "Kiinteistorajat"
IMAGETYPE PNG8
EXTENT 20000.000000 6570000.000000 788000.000000 7818000.000000
SIZE 256 256
MAXSIZE 4096
SHAPEPATH "/maps/kiinteisto"
IMAGECOLOR 255 255 255
DEBUG 5
PROJECTION
"init=epsg:3067"
END
WEB
METADATA
"wms_title" "Kiinteistorajat"
"wms_onlineresource"
"https://mapserver.gofferje.net/?map=kiinteisto&service=WMS"
"wms_srs" "EPSG:3067 EPSG:3857 EPSG:4326"
"wms_getmap_formatlist" "PNG,PNG8,JPEG"
"wms_enable_request" "* !GetLegendGraphic"
END
END
LAYER
METADATA
END
STATUS ON
TILEINDEX "rajat.shp"
TILEITEM "LOCATION"
TYPE RASTER
MAXSCALEDENOM 50000
PROJECTION
"init=epsg:3067"
END
ENCODING "windows-1252"
CLASS
NAME "Kiinsteistorajat"
STYLE
OUTLINECOLOR 0 0 0
END
END
PROCESSING "RESAMPLE=BILINEAR"
END
END
I created the tileindex in the /maps/kiinteisto directory with
ogrtindex rajat.shp rajat/*.shp
When I look at the attribute table in QGIS, it looks like it should
(according to the ms documentation). Example entries:
LOCATION
1 rajat/K2344H_kiinteistoraja.shp,0
2 rajat/K2433D_kiinteistoraja.shp,0
However, when I try to access that WMS layer with e.g.
https://mapserver.gofferje.net/?map=kiinteisto&service=WMS&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=340774.031465307693%2C6794806.480618176982%2C341675.648959146929%2C6795268.100126413628&CRS=EPSG%3A3067&WIDTH=1668&HEIGHT=854&LAYERS=Kiinteistorajat&STYLES=&FORMAT=image%2Fpng&DPI=79&MAP_RESOLUTION=79&FORMAT_OPTIONS=dpi%3A79&TRANSPARENT=TRUE
I get the following error:
[warn] [pid 15] mod_fcgid: stderr: CGI Request 10 on process 178
[warn] [pid 15] mod_fcgid: stderr: msDrawMap(): rendering using
outputformat named png (AGG/PNG).
[warn] [pid 15] mod_fcgid: stderr: msDrawMap(): WMS/WFS set-up and
query, 0.000s
msDrawRasterLayerLow(Kiinteistorajat): entering.
[warn] [pid 15] mod_fcgid: stderr: msDrawRasterLayerLow(): Unable to
access file. Corrupt, empty or missing file
'rajat/M4123A_kiinteistoraja.shp,0' for layer 'Kiinteistorajat'.
rajat/M4123A_kiinteistoraja.shp,0: No such file or directory
[warn] [pid 15] mod_fcgid: stderr: msDrawMap(): Image handling error.
Failed to draw layer named 'Kiinteistorajat'.
[warn] [pid 15] mod_fcgid: stderr: mapserv request processing time
[warn] [pid 15] mod_fcgid: stderr: (msLoadMap not incl.): 0.005s
[warn] [pid 15] mod_fcgid: stderr: msFreeMap(): freeing map at
0x560fcd81c200.
8380 - 172.21.1.16 - - [30/Apr/2025:10:22:42 +0300] "GET
HTTP/1.1" 200 671 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:138.0)
Gecko/20100101 Firefox/138.0"
As I wrote above, I tried all variations imaginable with relative and
also absolute paths (ogrtindex -write_absolute_path ...) but I can't get
this to work. I also double checked the paths inside the container and
the file permissions and all checks out.
I would really be grateful for any hints here!
-Stefan
(o_ Stefan Gofferje | SCLT, MCP, CCSA
//\ Reg'd Linux User #247167 | VCP #2263
V_/_ https://www.gofferje.net/ | https://www.saakeskus.fi/
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
