[MapServer-users] WMS layer from multiple ogrtindex'd shapefiles - no such file or directory
Stefan Gofferje
lists at home.gofferje.net
Wed Apr 30 01:15:54 PDT 2025
Hi Jukka,
On 4/30/25 10:57, Rahkonen Jukka wrote:
> I believe that what you try to do is possible, but myself I would not waste my time for that because the property boundaries of the whole Finland are available as a single GeoPackage file from https://asiointi.maanmittauslaitos.fi/karttapaikka/tiedostopalvelu/kiinteistorekisterikartta_vektori?lang=fi.
> Much more convenient than to struggle with thousands of shapefiles.
Oh cool, I'll check that, thanks!
I also found the issue with my setup... The layer type should be LINE,
not RASTER. Then it works just fine. The "File not found" error is a
little misleading...
-Stefan
(o_ Stefan Gofferje | SCLT, MCP, CCSA
//\ Reg'd Linux User #247167 | VCP #2263
V_/_ https://www.gofferje.net | https://www.saakeskus.fi
More information about the MapServer-users
