[MapServer-users] SOLUTION RE: Frustrating error: msLoadMap(): Regular expression error. Filename validation failed
Pascoe,Tim (ECCC) Tim.Pascoe at ec.gc.ca
Mon Feb 10 18:33:43 PST 2025
I stand corrected. With a little tweaking, running FastCGI as a local handler mapping under the application for Mapserver on IIS seems to have solved the issue. I have no idea why the inherited Handler from the IS root, with exactly the same settings, does not work.
Timothy Pascoe
Please note the return to our departmental E-mail address below. My Canada.ca address will also continue to work for the time being/Veuillez noter le retour à notre adresse électronique départementale ci-dessous. Mon adresse Canada.ca continuera également à fonctionner pour le moment.
Environmental Scientist, Water Quality Monitoring & Surveillance
Environment & Climate Change Canada (ECCC)
tim.pascoe at ec.gc.ca<mailto:tim.pascoe at ec.gc.ca> T: 905-336-6239 / C: 289-253-7857
Scientifique de l'environement, Surveillance de la qualité de l'eau
Environnement et Changement climatique Canada (ECCC)
[Environment Canada]
Sent: Friday, February 7, 2025 9:37 AM
To: Pascoe,Tim (ECCC) <Tim.Pascoe at ec.gc.ca>; MapServer Users <mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] Frustrating error: msLoadMap(): Regular expression error. Filename validation failed
Hi Tim,
>From https://mapserver.org/installation/iis.html#troubleshooting
The following error is returned (from MapServer 8.0) if allowPathInfo="false" is set in the handlers section for MapServer in the web.config file. This should be set to true:
     msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN validation failed.
You could also try the following in your CONFIG file. Note you'll need to restart IIS to pick up any changes. Also try adding some broken syntax (e.g. CONFIGX) to check the file is being picked up.
CONFIG
  ENV
    MS_MAP_PATTERN "."
Seth
web:https://geographika.net<https://geographika.net/> & https://mapserverstudio.net<https://mapserverstudio.net/>
mastodon: @geographika at mastodon.social<mailto:geographika at mastodon.social>
On Fri, Feb 7, 2025, at 3:25 PM, Pascoe, Tim (ECCC) via MapServer-users wrote:
I'm working on porting a development environment to our production server. Using:
Mapserver 8.2.2 binaries from GISInternals
IIS 10
Windows Server 2016
The permissions are the same on both servers, I have Mapserver set up as a FastCGI module and have the MAPSERVER_CONFIG_FILE Env variable set. I've attached the Config file here, but it's pretty simple, and I can confirm it's being read.
The error I'm getting is: msLoadMap(): Regular expression error. Filename validation failed
I've googled this, and only found one other user who seemed to have a similar problem. They never posted a clear solution, and their workaround was to point to the endpoint with no mapserv.exe in the path (just the endpoint), but had no idea why this worked. It did not work for me, however. What is confusing is that I have no validation for the files. I have a MAPS key set, which works on Development, and have set the MS_MAP_PATTERN to *.* to try and eliminate any validation mistakes. The map files are ones that have been in use for some time, with no issues. Hitting just the raw endpoint delivers the expected 'QUERY_STRING is set, but empty. 'but still also includes the Filename validation error.
Am I missing a PATH environment variable that is required?
Anyone have any ideas for me to test out?
Timothy Pascoe
MapServer-users mailing list
MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
  *   mapserver.conf
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250211/4a8e1c57/attachment-0001.htm>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250211/4a8e1c57/attachment-0001.gif>
More information about the MapServer-users mailing list
