[MapServer-users] SOLUTION RE: Frustrating error: msLoadMap(): Regular expression error. Filename validation failed
    Seth G
    sethg at geographika.co.uk
    Mon Feb 10 23:47:09 PST 2025
Hi Tim,
Glad you got it working.
What does the contents of your web.config in the root of Intepub look like (in particular the handlers settings?
        <handlers>
            <add name="MapServerFastCgi" path="*" verb="*" type="" modules="FastCgiModule" scriptProcessor="C:\Mapserver\bin\mapserv.exe"
            resourceType="Unspecified" requireAccess="Script" allowPathInfo="true" preCondition=""  />
        </handlers>
And do you have an example of a request that is failing? E.g. http://localhost/?request=browse
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Tue, Feb 11, 2025, at 3:33 AM, Pascoe,Tim (ECCC) wrote:
> I stand corrected. With a little tweaking, running FastCGI as a local handler mapping under the application for Mapserver on IIS seems to have solved the issue. I have no idea why the inherited Handler from the IS root, with exactly the same settings, does not work.
> *Timothy Pascoe***
> Please note the return to our departmental E-mail address below. My Canada.ca address will also continue to work for the time being/Veuillez noter le retour à notre adresse électronique départementale ci-dessous. Mon adresse Canada.ca continuera également à fonctionner pour le moment.
> Environmental Scientist, Water Quality Monitoring & Surveillance
> Environment & Climate Change Canada (ECCC)
> tim.pascoe at ec.gc.ca T: 905-336-6239 / C: 289-253-7857
> Scientifique de l’environement, Surveillance de la qualité de l'eau
> Environnement et Changement climatique Canada (ECCC)
> Environment Canada
> *From:* Seth G <sethg at geographika.co.uk>
> *Sent:* Friday, February 7, 2025 9:37 AM
> *To:* Pascoe,Tim (ECCC) <Tim.Pascoe at ec.gc.ca>; MapServer Users <mapserver-users at lists.osgeo.org>
> *Subject:* Re: [MapServer-users] Frustrating error: msLoadMap(): Regular expression error. Filename validation failed
> Hi Tim,
> From https://mapserver.org/installation/iis.html#troubleshooting
> The following error is returned (from MapServer 8.0) if ` allowPathInfo="false"` is set in the `handlers` section for MapServer in the `web.config` file. This should be set to `true`:
>      msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN validation failed.
> You could also try the following in your CONFIG file. Note you'll need to restart IIS to pick up any changes. Also try adding some broken syntax (e.g. CONFIGX) to check the file is being picked up.
> CONFIG
>   ENV
>     MS_MAP_PATTERN "."
> Seth
> On Fri, Feb 7, 2025, at 3:25 PM, Pascoe, Tim (ECCC) via MapServer-users wrote:
>> I’m working on porting a development environment to our production server. Using:
>> Mapserver 8.2.2 binaries from GISInternals
>> IIS 10
>> Windows Server 2016
>> The permissions are the same on both servers, I have Mapserver set up as a FastCGI module and have the MAPSERVER_CONFIG_FILE Env variable set. I’ve attached the Config file here, but it’s pretty simple, and I can confirm it’s being read.
>> The error I’m getting is: msLoadMap(): Regular expression error. Filename validation failed
>> I’ve googled this, and only found one other user who seemed to have a similar problem. They never posted a clear solution, and their workaround was to point to the endpoint with no mapserv.exe in the path (just the endpoint), but had no idea why this worked. It did not work for me, however. What is confusing is that I have no validation for the files. I have a MAPS key set, which works on Development, and have set the MS_MAP_PATTERN to *.* to try and eliminate any validation mistakes. The map files are ones that have been in use for some time, with no issues. Hitting just the raw endpoint delivers the expected ‘QUERY_STRING is set, but empty. ’but still also includes the Filename validation error.
>> Am I missing a PATH environment variable that is required?
>> Anyone have any ideas for me to test out?
>> *Timothy Pascoe*
>> Environment Canada
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> *Attachments:*
>>  • mapserver.conf
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250211/1c42dd4a/attachment-0001.htm>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250211/1c42dd4a/attachment-0001.gif>
More information about the MapServer-users
