[MapServer-users] Use SCALETOKEN in FILTER?
Seth G
sethg at geographika.co.uk
Thu Feb 13 03:31:43 PST 2025
Hi Jesper,
This looks like a bug - it should work as you expect it to.
Could you log an issue at https://github.com/MapServer/MapServer/issues ?
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Wed, Feb 12, 2025, at 3:13 PM, Jesper Kempe via MapServer-users wrote:
> Hi
> I am trying to show different levels of details based on zoom level in a map based on Natural earth 10m data (ne_10m_lakes.zip from https://www.naturalearthdata.com/downloads/10m-physical-vectors/) using the attribute scalerank in the shape file.
> My plan was to use SCALETOKEN to replace the value in a FILTER with the current max scalerank to use.
> But I cant get it to work. Nothing is shown in the map.
> Should it be possible to use a scaletoken in a filter expresssion?
> Looking at https://mapserver.org/development/rfc/ms-rfc-86.html#discussion it looks like it at least was planned to work?
> Now I get errors like this in the log file:
> [Wed Feb 12 13:50:20 2025].23938 replacing scaletoken (%ne_scalerank%) with (5) in layer->filter (ne_10m_lakes) for scale=221471921.250000
> [Wed Feb 12 13:50:20 2025].24460 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
> [Wed Feb 12 13:50:20 2025].24474 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
> [Wed Feb 12 13:50:20 2025].24482 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
> Using this mapfile:
> MAP
> CONFIG "MS_ERRORFILE" "ms_error.txt"
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> EXTENT -180 -90 180 90
> WEB
> METADATA
> "wms_title" "WMS Demo Server"
> "wms_srs" "EPSG:4326"
> "wms_enable_request" "*"
> END
> END
> LAYER
> DEBUG 5
> NAME 'ne_10m_lakes'
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
> DATA "ne_10m_lakes.shp"
> SCALETOKEN
> NAME "%ne_scalerank%"
> VALUES
> "0" "10"
> "1000" "8"
> "10000000" "5"
> END # VALUES
> END # SCALETOKEN
> FILTER ([scalerank] < %ne_scalerank% )
> CLASS
> STYLE
> OUTLINECOLOR "#647078"
> WIDTH 1
> COLOR "#EBEEF0"
> END
> END
> END
> END
> For this request
> https://myserver/wms?&service=WMS&request=GetMap&layers=ne_10m_lakes&styles=&format=image%2Fpng&transparent=false&version=1.1.1&map=ne_10m_lakes.map&height=512&width=512&srs=EPSG%3A4326&bbox=-180,-90,180,90
> Worth noting is if I replace FILTER ([scalerank] < %ne_scalerank% ) with FILTER ([scalerank] < 5 ) in the mapfile it works fine.
> Anyone with thoughts or ideas on how this can be solved?
> I am on Mapserver 7.6.4.
> Thanks,
> Jesper
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250213/cf963a39/attachment.htm>
More information about the MapServer-users
