[MapServer-users] Use SCALETOKEN in FILTER?
Seth G
sethg at geographika.co.uk
Thu Feb 13 03:52:37 PST 2025
Hi Jesper,
As a workaround (unless this was the intended design), you can use the following approach:
SCALETOKEN
NAME "%ne_scalerank%"
VALUES
"0" "([scalerank] < 10)"
"1000" "([scalerank] < 8)"
"10000000" "([scalerank] < 5)"
END
END
FILTER "%ne_scalerank%"
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Thu, Feb 13, 2025, at 12:31 PM, Seth G via MapServer-users wrote:
> Hi Jesper,
> This looks like a bug - it should work as you expect it to.
> Could you log an issue at https://github.com/MapServer/MapServer/issues ?
> Seth
> On Wed, Feb 12, 2025, at 3:13 PM, Jesper Kempe via MapServer-users wrote:
>> Hi
>> I am trying to show different levels of details based on zoom level in a map based on Natural earth 10m data (ne_10m_lakes.zip from https://www.naturalearthdata.com/downloads/10m-physical-vectors/) using the attribute scalerank in the shape file.
>> My plan was to use SCALETOKEN to replace the value in a FILTER with the current max scalerank to use.
>> But I cant get it to work. Nothing is shown in the map.
>> Should it be possible to use a scaletoken in a filter expresssion?
>> Looking at https://mapserver.org/development/rfc/ms-rfc-86.html#discussion it looks like it at least was planned to work?
>> Now I get errors like this in the log file:
>> [Wed Feb 12 13:50:20 2025].23938 replacing scaletoken (%ne_scalerank%) with (5) in layer->filter (ne_10m_lakes) for scale=221471921.250000
>> [Wed Feb 12 13:50:20 2025].24460 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
>> [Wed Feb 12 13:50:20 2025].24474 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
>> [Wed Feb 12 13:50:20 2025].24482 msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
>> Using this mapfile:
>> MAP
>> CONFIG "MS_ERRORFILE" "ms_error.txt"
>> STATUS ON
>> PROJECTION
>> "init=epsg:4326"
>> END
>> EXTENT -180 -90 180 90
>> WEB
>> METADATA
>> "wms_title" "WMS Demo Server"
>> "wms_srs" "EPSG:4326"
>> "wms_enable_request" "*"
>> END
>> END
>> LAYER
>> DEBUG 5
>> NAME 'ne_10m_lakes'
>> TYPE POLYGON
>> PROJECTION
>> "init=epsg:4326"
>> END
>> DATA "ne_10m_lakes.shp"
>> SCALETOKEN
>> VALUES
>> "0" "10"
>> "1000" "8"
>> "10000000" "5"
>> END # VALUES
>> END # SCALETOKEN
>> FILTER ([scalerank] < %ne_scalerank% )
>> CLASS
>> STYLE
>> OUTLINECOLOR "#647078"
>> WIDTH 1
>> COLOR "#EBEEF0"
>> END
>> END
>> END
>> END
>> For this request
>> https://myserver/wms?&service=WMS&request=GetMap&layers=ne_10m_lakes&styles=&format=image%2Fpng&transparent=false&version=1.1.1&map=ne_10m_lakes.map&height=512&width=512&srs=EPSG%3A4326&bbox=-180,-90,180,90
>> Worth noting is if I replace FILTER ([scalerank] < %ne_scalerank% ) with FILTER ([scalerank] < 5 ) in the mapfile it works fine.
>> Anyone with thoughts or ideas on how this can be solved?
>> I am on Mapserver 7.6.4.
>> Thanks,
>> Jesper
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250213/bc694008/attachment-0001.htm>
More information about the MapServer-users
