[MapServer-users] Ubuntu versions for MapCache?
Big-Edd
bigedd at gmail.com
Thu Feb 13 21:26:54 PST 2025
Hello,
I begun following instructions here.. ..
https://mapserver.org/mapcache/install.html
This is what I see when attempting to install the required, recommended and
optional packages.. ..
$ sudo apt install -y \
git \
cmake \
apache2-threaded-dev \
libpng12-dev \
libjpeg62-dev \
libcurl4-gnutls-dev \
libpcre3-dev \
libpixman-1-dev \
libfcgi-dev \
libgdal1-dev \
libsqlite3-dev \
libtiff4-dev \
libdb4.8-dev \
liblmdb-dev \
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package libdb4.8-dev is not available, but is referred to by another
package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package libpng12-dev is not available, but is referred to by another
package.
Package libtiff4-dev is not available, but is referred to by another
package.
However the following packages replace it:
libtiff-dev
E: Unable to locate package apache2-threaded-dev
E: Package 'libpng12-dev' has no installation candidate
E: Unable to locate package libgdal1-dev
E: Package 'libtiff4-dev' has no installation candidate
E: Package 'libdb4.8-dev' has no installation candidate
Cheers,
Eddie.
On Fri, 14 Feb 2025 at 09:38, Big-Edd <bigedd at gmail.com> wrote:
> And where MapCache 1.14.1 is required, so we compile from source, are all
> dependencies are covered?
> On Fri, 14 Feb 2025 at 01:05, Richard Greenwood <
> richard.greenwood at gmail.com> wrote:
>> Ubuntu 22.04 has MapCache 1.12.0
>> Ubuntu 24.04 has MapCache 1.14.0
>> On Thu, Feb 13, 2025 at 1:38 AM Big-Edd via MapServer-users <
>> mapserver-users at lists.osgeo.org> wrote:
>>> Hello,
>>> Which LTS versions of Ubuntu are known to run MapCache, without the need
>>> to add third party repositories, or manually download packages?
>>> Cheers,
>>> Eddie.
>>> MapServer-users mailing list
>>> MapServer-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Richard W. Greenwood
>> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250214/540de1a8/attachment.htm>
More information about the MapServer-users
